Swaybar end link adjust
With the slightly adjustable endlinks on the stock front swaybar does it matter
where they are? Assuming I want my car to go straight and is in good alignment is there a difference if they are both up, or down in the slots?
Matt! 92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride! 83 Honda Magna v45 "Grendel" *Free after mail in rebate |
Anyone?
Bueller.....bueller?
Unless you are setting the car up for only left or right turns, then adjust where there is no preload.
Right, but would it matter if they were both all the way up, or all the way down?
I assume if they are both in the same spot, and everything else is equal in the suspension then it wouldn't. I assume then that the adjustability is in case the left and right suspension AREN'T equal. So I guess I answered my own question. Or rather I assume I did.
Since my front end is too low to get on my ramps could I do it just by turning the wheels and unbolting both sides, then bolting them back wherever they "fall"?
no adjusting your sway bars will not adjust your ride hight
But yea, loosen them, and tighten where they fall. Bolt them up when the wheels are strait just to be safe.
