Old 02-12-2012, 12:53 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
fried ecu?!
while fixing the alternator connector, one of the wires kinda touched the alt body for like 1 sec before I take them apart
I think one of the fuses blew but all of them were still connected(there was a little smoke in the fuse box)
now nothing works...
what have I done ?
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 02-12-2012, 01:03 PM
Re: fried ecu?!
Check your fusible link. It is in the fuse box and looks like a thick piece of wire. They're about $5 new from Subaru.
Old 02-12-2012, 01:13 PM
The NEWBIE
Re: fried ecu?!
thank you very much
yeah that was it...it looked ok but when i took it out it came apart
so the ecu is okay, right?
DIY FTW!
Old 02-12-2012, 01:19 PM
Re: fried ecu?!
Originally Posted by david_12121 View Post
thank you very much
Everything else SHOULD be okay if it tripped the fusible link. The only situations where anything else gets damaged is if there is an overvoltage/overcharging situation when the voltage regulator goes out in the alternator. This can lead to fried control modules and wiring, but in your situation, replace the link and you should be good to go.
Old 02-12-2012, 01:26 PM
Re: fried ecu?!
When doing any electrical work, always disconnect the battery first.
Old 02-12-2012, 01:38 PM
Re: fried ecu?!
Check your fusible link. It is in the fuse box and looks like a thick piece of wire. They're about $10 new from Subaru.
Fixed your post.
82301GA060
Subaru current price is $10.02
Old 02-12-2012, 02:07 PM
The NEWBIE
Re: fried ecu?!
word
Fixed your post.
82301GA060
is there any substitute part i can get from autozone or other part stores?!
DIY FTW!
Old 02-12-2012, 02:56 PM
Re: fried ecu?!
word
Since electrical systems and ECUs, TCUs, wiring harnessed are kind of expencive, why not just use the right, proven, Subaru part?
Old 02-12-2012, 03:07 PM
The NEWBIE
Re: fried ecu?!
the OEM part didn't seem of a high quality...I mean how could it? it's just a copper wire
I couldn't find anything like this in part stores so I guess that leaves me with one option
thank you guys...great help like always
DIY FTW!
Old 02-12-2012, 03:55 PM
gbianchi gbianchi is offline
Re: fried ecu?!
I went to napa showed them the old one bought same gauge wire and connectors and made 2 of them for about 5 bucks..................G
I thimk ther4 I an, what? huh!
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
05legacy gt limited "Moon" blue.
06 Subaru legacy gt limited.
Old 02-12-2012, 05:35 PM
Re: fried ecu?!
Hmm, from Subaru the part lasts twenty years, and costs $10.00.
So FIFTY CENTS A YEAR is too much to keep your SVX running properly.
http://www.youtube.com/watch?v=9x3M8310qzs
Old 02-12-2012, 05:44 PM
Re: fried ecu?!
http://www.youtube.com/watch?v=UzKAt...eature=related
Old 02-12-2012, 06:30 PM
Re: fried ecu?!
Couldn't agree more. Don't go for a cheap fix on something like this. That copper wire you got with connections may not be the same resistance as the fusible link and may take more to "blow" it leading to a possibility of frying things. As OT said, $10 is a lot cheaper than replacing all of the control modules and some wiring in the car. And YES, it does and has happened. Just ask Dayle. I had to send an ABS module, TCU and a few other modules because of an overcharging situation. Not to mention the few other modules he at least had on hand to replace on that car.
Do things right, or don't do them at all.
Old 02-12-2012, 06:46 PM
The NEWBIE
Re: fried ecu?!
actually it could only last 'til the next time you start it up but that's not the point...I was looking for the exact part, from another store because subaru dealership is closed on sundays and I'm going to need the car tomorrow
why do you guys have to tie everything with money and destroyed or burnt cars?!
i strongly advise getting a legit part instead of a made up one because the link is supposed to have the high angle and that is what takes the wires apart when melted...if it was short and/or made out of a more flexible wire, it wouldn't have blown
DIY FTW!
Old 02-12-2012, 06:52 PM
Re: fried ecu?!
Be sure to order a couple, or find some in a local junkyard with Subies. Subaru used the same ones in just about every subie in the 90's, and maybe even newer as well. If you need one ASAP
