aftermarket power antenna
http://www.pepboys.com/product/detai...rior/antennas/
Has anyone used this product? The web site says it fits an SVX. Wondering if that's correct... |
Re: aftermarket power antenna
For that price you could replace just your mast, if that is the only thing wrong.
part# 86322PA010 $55.40
Michael, no disrespect intended, but have you personally replaced a Subaru SVX mast? Twenty year old plastic/screws/grease/gears/etc./etc. It should take at least an hour less if the product actually fits.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 01-25-2013 at 06:34 PM. |
The better question is what would give the best reception. I was surprised at how mediocre my reception is with the new Pioneer radio. It has the top of the line tuner from Pioneer which is known for its tuners.
Yes I have replaced one, and it wasn't as bad as it sounds. That was at least 6 years ago tho.
My concern would be the shape of the antenna motor assembly. The OEM one has a bend to it so that motor sits more horizontal. Would a straight one fit in the space?
However the one that just changed in my 253k Pearlie was a plastic breaking, rusted screw PITA.
So is this part/part number still available? Went looking at mine since it was stuck in the extended position when I bought it and looked bent. Plugged it in and it retracted half way, so the motor works. An aftermarket power ant doesn't look like it will fit due to the fender well being so close (guess that's why subaru designed the curve tube for it). Looks like the replacement mast would be the easier way to get this going again and probably the same price for a functional used one.
01- Impreza RS Original Owner 92- SVX LS-L |
So I got my OEM replacement and it works beautiful. Only thing is it has an additional grounding wire that was not on the original antenna, and there is not a handy screw to attach it to. So I left it hanging. Both AM and FM seem to be coming in fine w/o any engine noise. I could ground it with a new screw. Comments?
