pistons n cams
im tryin to build up my motor..i was wondering if i would have to take out the whole motor to install my pistons n cams does an1 hava answer 4 me? thx plz help
Re: pistons n cams
Are you seriously asking if you have to pull the motor out of the car to change the pistons in it?
Re: pistons n cams
yes i am am not a mechanic buddy simple question i need a simple answer ,just wondering how much i need to invest, dnt be mad cause u got 227000 on ur svx no **** rollin restoration
Re: pistons n cams
If you're not a mechanic you won't be changing out pistons yourself, so why ask in the first place?
Short version? Several thousand. Figure ~$3000 for pistons and cams, probably another $2500-4000 for machine work, reseal kit, new crank/rod bearings... You also need some sort of engine management since the stock MAF runs out at ~250HP. I doubt you'll get it done for less than $7000. Probably closer to 10K to do everything properly.
Re: pistons n cams
thx man good to knw i didnt knw id have to get machine work done as well
Re: pistons n cams
lol I can see much fail in this job... lol this isn't a honda... the EG33 will take a lot more work to build than I think you'll be willing to put in. If you are serious about this however hit me up and I can get you all the parts you need to build the engine for a good price.
Re: pistons n cams
That is 222,700 kilometers on the car not 222,700 dollars invested
