Old 01-27-2015, 01:01 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Suspension parts question
As part of the restoration of my SVX, i've been trying to restore the suspension. I got the AMR Engineering struts but I still have a lot to do to get the car back to a comfortable driving experience.
That being said, Nate has already mentioned that my front sway bar bushings were shot so i'm going to order new ones for that. I've also ordered the 15/20-min mods from Tom (thanks Tom for that), but are there any more parts that I should get?
I was trying to figure out if there were any other rubber parts that probably should be replaced from the pics on subaruparts.com and saw there are also rear bushings that I should probably replace but anything else?
If anyone has any suggestions, I'd love to hear them. Also, if you happen to know the part #'s for those, they would be greatly appreciated as well.
Thanks!
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 01-27-2015, 03:28 PM
Re: Suspension parts question
I've found the rubber bushing in the SVX to be quite robust. Part of this is due to their geometry - they don't suffer from too much motion compared to other car's setups. One thing that was really hurting on my car was the rear diff bushings. This is exacerbated by the fact that I jack my car up by the diff, putting lots of load on the bushings in a direction they were never intended to take. While there may be replacement options out there I wasn't confident in being able to remove the old bushings cleanly without causing too much trouble. Solution: buy windshield urethane from a local glass shop ($15, fits in a caulking gun) and fill in the voids of the bushing to strengthen it.
Old 01-28-2015, 08:49 AM
halistan's Avatar
Grand Poo-Bah
Oh that's a good idea! I hadn't thought of that. I'll take a look at them this weekend and see how bad a shape they are in. That might work until I ever decide to replace them outright. Thanks for the info!
Ray
Old 02-04-2015, 02:04 AM
lidyhury$ lidyhury$ is offline
Banned
Search suspension parts, go to maxspeedingrods.com
Old 02-04-2015, 01:02 PM
halistan's Avatar
Grand Poo-Bah
Nice, I didn't know they had struts. Too bad they don't make them for the SVX. I wonder if these would work on our cars?
http://www.maxspeedingrods.com/subar...nsion-kit.html
Old 02-04-2015, 01:26 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
I used a Whiteline kit and trimmed the inserts to fit the diff and subframe bushings.
Used this write-up to do it.
http://www.svxworldforums.com/forum13/1965.html
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 02-05-2015, 07:54 AM
halistan's Avatar
Grand Poo-Bah
Thanks! I'll give this a try
