Old 08-09-2014, 03:02 PM
ScottnSvx ScottnSvx is offline
fwd to awd conversion, 1994 L
curious to see how impossible or expensive could it be to convert your fwd svx to an awd svx. any help or suggestions would be appreciated thanks.
Old 08-09-2014, 03:47 PM
Re: fwd to awd conversion, 1994 L
Get an AWD transmission,
driveshaft,
rear subframe,
rear differential and axles,
an AWD TCU,
and get to work!
I have done several.
It sure helps to have a lift and a really good transmission jack!
Old 08-09-2014, 07:37 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Had mine converted years ago and still runs awsome, good investment if you break your FWD trans.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-13-2015, 01:38 PM
deadwood's Avatar
deadwood deadwood is offline
Cost of usual conversion??
94 Lexus SC300
01 Ford Focus ZX3
07 Honda Odyssey EX-L
89 Yamaha FZR600
Old 01-13-2015, 02:49 PM
is the gas tank the same, heard most FWD Scoobs have different gas tanks, and most Scoob AWD tanks have a hump indented to clear the main driveshaft.
are rear hubs on a FWD splined, or not? probably need hubs too for back.
why not just get a AWD one? These cars are not ever hard to find. You can search Craigs every week of the year, and come up with 100's always for sale, and not very pricey.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 01-13-2015, 02:51 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Gas tank should be the same, especially since there weren't many FWD SVXi.
Should be easy to verify by just crawling underneath and taking a look.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
