Old 02-26-2008, 04:41 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Part # for hi-flow cat converter
Just as the title says and where to get it. I've looked everywhere and can find the magnaflow cat.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 02-26-2008, 04:45 PM
Part number is 94007.
Old 02-26-2008, 04:57 PM
thanks..............
Seth
Past subies:
Other toys:
Old 03-01-2008, 04:34 PM
Ok I have another stupid question: could I reuse the 3 gaskets or should i go buy new ones? And the magnaflow cat does it fit directly in place of the old one or will I have to rig it up? Just want to clear these up before I put it in because the noise and gas mileage loss is killing me
Seth
Past subies:
Other toys:
Old 03-01-2008, 04:40 PM
The stock main cat has flanges, and the magnaflow one has slip-on pipes. Also, the inlets and outlets are different sizes. You won't be able to use it without modifying the rest of your exhaust system. What I did was cut the pre-cats after the first 45* bend, and cut the midpipe just in front of the resonator (get rid of the small bend behind the main cat). Then I used 2" flex pipes from the pre-cats into the Magnaflow, and a small piece of 2.5" pipe from the back of the cat to the resonator. You'll need adapters as well, but I can't recall the size offhand.
I'll have my car up on jackstands tomorrow, I can take pictures if it will help.
Old 03-01-2008, 08:36 PM
Pics will help if you can get them. Thanks
Seth
Past subies:
Other toys:
Old 03-02-2008, 12:54 PM
Here's some pictures:
The pre-cat pipes were cut 4-6" back from the end of the cat's, and adapters were used to get the flexible pipes to fit:
The flex-pipes bend and slide onto the inlets of the Magnaflow cat:
There's a small piece of pipe off the back of the Magnaflow, which is clamped to the stock mid-pipe that was cut a couple inches ahead of the resonator:
You have to cut the mid-pipe a bit further back than just after the flange. Take a look and you will see it bends slightly between the flange and the resonator. You need to cut this bend out or the resonator will hang down so low it will scrape on things. Trust me.
Something to be mindful of is that this is just a temporary solution. In a completely dry place I would give those flew pipes a year before failing. Somewhere with snow and salted roads I'd give them 6 months. That's the reason one of mine is new, I blew up the old flew pipe at the snow track. That was the loudest, most unpleasant drive home of my life.
Here's what happened to the old flex pipe:
Most of the unwinding was from me tearing it off today, but it sheared off at the connection to the main cat.
So again, go ahead with this, but start saving for a proper exhaust, wherever you want to get it from. I went with this because I couldn't afford the $2300 the shop wanted to replace the pre-cats so I could pass safety. I'll be replacing it with a complete stainless system soon enough.
Old 03-02-2008, 04:39 PM
Thanks for the pics. What length are the flex pipes?
Seth
Past subies:
Other toys:
Old 03-02-2008, 04:40 PM
18". They cost me something like $12.50 each. Make sure you get the 2-1/8" ones, a 2" is too small.
Old 08-28-2008, 07:45 PM
rrhenderson's Avatar
rrhenderson rrhenderson is offline
MacArthur
Re: Part # for hi-flow cat converter
How in the world can Magnaflow claim this Catalytic converter as a part
(#94007) that fits an SVX, considering the cutting and pasting involved in its installation you have described, and as lasting only 6 months or less? I was on the verge of ordering that part, too, until reading your post.
Have also read even the OEM Subaru catalytic converters have to be monkeyed to fit because of a redesign of the part. Am paralyzed now, temporarily anyway.
Thanks for the helpful detailed information.
~ Robert
Old 08-28-2008, 07:48 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I think he meant the piping he chose only lasted 6 months due to the harsh salt treatments that they have up north.
I had my old magnaflow for 4 years without a problem.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 08-28-2008, 07:59 PM
MacArthur
Hey dere. Do you recall how you installed yours? Was it the same Magnaflow part# ? Thanks.
~ Robert
Old 08-28-2008, 08:12 PM
Tim's Avatar
Tim Tim is offline
I honestly dont remember. It's been such a long time. I just remember it was a magnaflow 1 to 1 that Dayle sells.
I had an exhaust shop near me fabricate all the necessary bends. The only thing I can really provide are pictures and sound clips. The more recent exhaust I have now consists of a magnaflow 2-in-1.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
