Old 02-23-2008, 11:37 AM
snofrek's Avatar
snofrek snofrek is offline
SubyFREAK
Send a message via MSN to snofrek
Exclamation why wont my my rear wheels drive?
i notice that a little after i bought my car, my rear wheels stopped driving and now my car is just front wheel drive? what goin on?!?!?!?! ive been told that i need to add fluid, but i needed to know from peoples that knew SVX's.... so if it is fluid, i need to raise the rear end to get to the rear differential, right? probably have to raise the front to make the car level, so the fluid will be even?...
Old 02-23-2008, 11:53 AM
ShiuludeSVX's Avatar
Try this first
If your worried about Fluid, then check under the Hood first. Stand over the Battery from the Drivers Fender, and look for a yellow handle to your right, and down, under the Brake Resivore, at the rear of the engine {that's the Tranny Dipstick}. Do this on a level area.
Frankly, there is not much chance of your Rear Differential being anywhere near empty, unless the lower plug came out {yup, there's 2}.
Check in your main fusebox while your up there. It's forward of the Shock Tower. If the fuse is IN for FWD {and a good fuse}, then your forcing the rear to shutdown. This is what's known as the "Limp Home" mode. If someone else put the fuse in, then they didn't tell you something.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 02-23-2008, 12:15 PM
snofrek's Avatar
SubyFREAK
the tranny fluid is fine, ive checked that b4, i just dont know y the rear wheels are not driving, they were when i picked up the car, when i bought it, but then a week or so after they stopped driving?!?!?!
Old 02-23-2008, 12:47 PM
Did you check for a fuse like was suggested? If that isn't it, then there are other problems.
Old 02-23-2008, 02:41 PM
snofrek's Avatar
SubyFREAK
k, i looked and there is no fuse in the FWD slot..... so now wat?
Old 02-25-2008, 02:57 PM
ridered777's Avatar
Finally HAS a 3rd pedal!!
Pull codes.
My money is on Solenoid C.
-Craig
Old 02-25-2008, 03:39 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
If you have your car parked in a quiet location, you can just turn the ignition key to on and you should hear the solenoid below you.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-25-2008, 03:49 PM
snofrek's Avatar
SubyFREAK
Originally Posted by ridered777 View Post
Pull codes.
ok, how do u pull codes and where is solenoid C? i havent had my car for very long so i still dont know how to do some stuff yet...
Old 02-25-2008, 05:08 PM
Blinks
Pick a morning when you can sit for a minute....
Turn the key to ignition, and start the engine....
The computer should give a number of blinks on the green"Power" light, at the center bottom of your Instruments.
Look in the "How To's" for the blink codes.
Edit......navigate here ----> http://www.subaru-svx.net/photos/user.php?How-To|14263
The Worm
_______________
No Mods, 33K Miles
Old 02-25-2008, 05:38 PM
SVXRide's Avatar
There is actually a different method to pulling TCU codes (vs ECU codes).
-Bill
Old 02-25-2008, 06:44 PM
Thought I'd throw this out there:
How do you know the rear wheels aren't being powered anymore?
Old 02-25-2008, 07:43 PM
snofrek's Avatar
SubyFREAK
i got stuck in the snow and only the front wheels turn and also when im at a stop, and smash the gas it burns out the front wheels, when i got the car, when i did that, it only chirped thefront wheels and then the rear wheels hooked up....
Old 02-25-2008, 08:00 PM
Ah, gotcha. An SVX stuck in the snow would be a new sight to me, my car is one of the most capable things I've ever seen on the white stuff.
You might want to avoid smashing the pedal while you know your drivetrain isn't working 100%. Going from something relatively simple like Sol. C gone stupid to a nuked trans would make for a bad day.
Old 02-25-2008, 08:04 PM
snofrek's Avatar
SubyFREAK
oooooh yaaaa! ok so i got the codes and how to check them so that will be my next thing to do! i'll let cha know what i get...
