Old 10-30-2012, 04:47 PM
immortal_suby's Avatar
Thread Killah
Re: Testing coil packs?
Dumb question but I don't know the answer - can you unplug the coils with the motor running or will you be shocked?
Locker Link
2015 BRZ Limited 6MT
Old 10-30-2012, 05:19 PM
No, there is only 12Volts DC on the coil wires.
Old 10-30-2012, 08:24 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
If you can get to the connectors! I can't get my hands down there with the airbox on. It's a whole lot easier to just unplug injectors, IMO.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 10-31-2012, 10:45 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
That was Alan from The Burg......
You know, Landshark!
I found a picture of the shark.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 10-31-2012, 08:58 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Ive seen this mentioned before. Can someone explain how unplugging the injectors help test if the coils are bad? I have an idea, but an explaination with steps would be helpful. Thanks
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 10-31-2012, 11:23 PM
EdWindows's Avatar
Well, if you have no spark to ignite the fuel, then unplugging the injector does nothing to the engine.
When you unplug an injector on a cylinder with a working coil, the engine bogs and starts missing, so you know that's not the cylinder with the bad coil.
Old 11-01-2012, 02:16 AM
This is correct,
but if you have a weak coil/spark then the engine will miss with the fuel injector disconnected,
but can still have a bad coil.
Old 11-01-2012, 06:57 AM
dragoontwo dragoontwo is offline
If there is no spark to a cylinder, unplugging the injector will yeild no change in the engine performance at idle. For instance if you unplug an injector for a cylinder that has spark, the engine will run noticably rougher at idle.
'92 SVX LS Pearl White - 6mt
Old 11-01-2012, 10:27 AM
theflystyle's Avatar
i wish i had taken a picture of the coil pack when tom was changing the plugs last weekend. his exact words "i have never seen a coil look like that before"
1994 SVX LSi
2008 Legacy 3.0R
Old 11-01-2012, 11:31 AM
One of mine went bad, but looked just fine.
Old 11-01-2012, 03:04 PM
dannmarr's Avatar
I work for my SVX
This is correct,
Thanks, this was my issue. Sometimes it's a good idea to physically look at the coil for cracks. Thanks for all the responses!
Subaru SVX for fun
