Serpentine belt working its way off
Hello once again. I was left half stranded the other day when i discovered that my serpentine belt had split in half. At the time i didnt think much of it, had a friend take me to a NAPA store and i replaced the belt in the parking lot. I drove it home and all seemed well. Today i go out and im checking to make sure everything is still in order when i see that its already working itself off the crank pulley. I'm now under the impression that this is what caused the failure of the first belt. I tightened the belt pretty well when i put it on. Is this a sign of it not being tight enough? Is it a sign of the tensioner not being completely straight? Or is it a sign of the crank pulley being junk?
Thanks again as always |
Re: Serpentine belt working its way off
Re-seat the belt and watch how the crank pulley spins with the engine running. The 2-piece dampened pullies have been known to separate along the rubber seam. You can also make a chalk/whiteout line across the rubber part to see if the inner and outer parts are staying together.
there is rubber showing along the front side of the pulley...this is not good?
No, it's normal to see the rubber joining layer, but the two metal parts should rotate as a unit with no wobble.
I just had a problem with the main pulley on my crank coming loose. It caused a wobble that tore up a set of belts and caused another to keep falling off before I had it fixed. The fix is only temporary as the threads were beginning to strip so soon I will need to replace the crank and while I am at it have the engine rebuilt. Check to make sure its not that, as letting it go will cause some damage.
96 LSi with 100,000+ Miles Owned Since Late June 2008 Things Fixed Thus Far Airbags-Self Installed (I hope they work) |
