Old 08-25-2008, 09:59 AM
SVXyGirl's Avatar
SVXyGirl SVXyGirl is offline
Angry Brake help....
I'll start from the beginning... About this time last year my Claret SVX started squeaking when coming to a stop. It got worse as I kept driving. Brake pads were fine. With the help of some of the people on the forum, I narrowed it down to the seals leaking in the calipers. OT sent me a used caliper for the front. I replaced that and some of the squeaking had stopped. Then I replaced one of the calipers on the rear. That one silenced but the others were squeaking. It seemed that every caliper was leaking. No surprise since this is a 16 year old car. So I decided to get brand new calipers all around. While I was at it, I decided to get new d/s rotors and ss lines. I wanted to upgrade the brakes anyway, so I felt this was the best time.
Now I have a new problem. When coming to a gradual stop or slowly accelerating from a stop, I hear a loud screeching. Like nails scratching a chalkboard. OT recommend I check to make sure the heat shield wasn't rubbing against the rotor. I checked and nothing is rubbing against the rotor. I pushed the heat shield away anyway. I drove the car around my driveway to see if it went away. All seemed fine. I took the car out this morning and the screeching has started again. I'm getting impatient with this car right now. I don't even want to drive it because every time I come to a stop I'm clenching my teeth at the sound. Help?
Rebecca
06 Suzuki Boulevard M50 7k
Past SVXs:
96 SVX Bourdeaux LSi (Sold)
Old 08-25-2008, 10:59 AM
Manarius's Avatar
Manarius Manarius is offline
Re: Brake help....
If you do a few 60-0 stops, it might wear down whatever is causing the screeching sound.
-Jason
-Obi Wan Kenobi
Old 08-25-2008, 12:57 PM
Re: Brake help....
Yea, have you bed the pads yet??
tom
Old 08-25-2008, 02:25 PM
dennyo dennyo is offline
Re: Brake help....
i wonder if it isn't something scuffing on the axles?
Old 08-25-2008, 02:38 PM
SVXyGirl's Avatar
Re: Brake help....
Ok guys I will do some stops tonight and let you know if the sound stops.
Rebecca
Past SVXs:
Old 08-25-2008, 03:06 PM
GreenMarine's Avatar
From POST-***** to LURKER
Re: Brake help....
Can you determine an individual corner that the sound is coming from? That might help in the diagnosis of the problem
~ Chris
Old 08-25-2008, 04:11 PM
Re: Brake help....
Rebecca,
I just now saw this.
Call me, or bring it here.
If need be I'll come and get it!
Old 08-25-2008, 06:01 PM
SVXyGirl's Avatar
Re: Brake help....
~ Chris
Sounds like the passenger side rear, but I am not certain.
I'm going to try and drive the car up to Tom's tomorrow. That may be my only free day for awhile.
Rebecca
Past SVXs:
Old 08-25-2008, 08:14 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Brake help....
I had a similar problem. I know this might sound impossible, but I actually over tightened the bottom bolt on the caliper. It did not bottom out, it just protruded far enough to touch the rotor. Can't hurt to check.
Old 08-25-2008, 08:30 PM
SuberNatural SuberNatural is offline
Re: Brake help....
I had this problem and it turned out to be a pad guide/slide. It would be fine for a little while then things would heat up some and it would start rubbing on the flat edge of the rotor.
It would only do this when slowing to a stop, not while slowing or light braking.
May not be your problem but it would be worth a look.
Old 08-26-2008, 12:01 AM
kwren's Avatar
kwren kwren is offline
Re: Brake help....
Usually is
Always boils down to not getting it put back together exacxtly right
Keith
Old 08-26-2008, 06:14 AM
Re: Brake help....
The replacement calipers came with new slides, but now that you guys mention it the new mounting bolt for the right rear was different than the standard bolt...
I'll find out today.
Old 08-26-2008, 04:32 PM
SVXyGirl's Avatar
Re: Brake help....
Thanks Tom. Turned out to be the passenger front clip draging on the rotor. It was kind of strange, but it is fixed. For once, my brakes are actually quiet.
Rebecca
Past SVXs:
Old 08-26-2008, 05:13 PM
Re: Brake help....
Glad I could shed some light on it as well.......
