Old 06-27-2012, 01:37 AM
crazyhorse's Avatar
242,000 mi on oem trans
4eat technical questions
Im asking some questions about the 4eat to determine if a paddleshift option could be "piggybacked" onto the existing tcu. As well as a 5, or 6spd tranny suits the svx, i think a paddleshift fits the spirit of the car as well.
What i need to know is how the trans shifts from drive back. IE 3-2-1. Is there a mechanical link between the shifter, and the trans, or does the fan switch simply tell the tcu a lower gear has been selected?
My thought process is, that if its just electrical, a small 12v industrial plc can be used to trick the tcu into thinking the shifter has been moved. it would be a simple plug and play solution for any 4eat equipped subie.
"42"
Current Stable By Age:
Old 06-27-2012, 02:30 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Re: 4eat technical questions
While researching, have you considered a sequential gearbox to go with that?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 06-27-2012, 02:46 AM
crazyhorse's Avatar
Considered, yes. Feasible, no. LOL. While im working on an SVX, im looking at a marketable kit i can sell for almost any 4eat equipped Subaru. The Impreza guys would "eat" this up, pun intended lol
"42"
Old 06-27-2012, 04:16 AM
jetboy's Avatar
I would probably buy one as I drive uphill a lot and 4EAT is not exactly sporty in those situations.
Why not feasable?
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 06-27-2012, 08:30 AM
I don't get it, we already have a downshift paddle, its the gas pedal.
I got them silly paddle shifters in the 2010 legacy, I don't think I have used them accept that first week to try them out..
P.S.
Whoever thought it was a good idea to mount the paddle shifts on the steering wheel, so they change position when your turn the wheel, is a moron.
Instead they should have been on the steering column like the blinkers, so that they don't move.
Really, what good is a paddle-shift when I'm trying to hard corner a right 90º and the up-shift paddle is in my crotch!
Old 06-27-2012, 08:42 AM
I had the select shift on the Accura and it felt silly, shift and wait a second or 2 , or shift down and it won't. The 5 and 6 speed really make the car feel sporty.
Old 06-27-2012, 09:11 AM
This is an idea that has been kicked around before. Did you search older threads?
I'm sure it could be done.
Old 06-27-2012, 09:47 AM
I found the paddle shifters on my 2010 Outback to be convenient at times. When the gear selector is in the manual position [+/-] it gives me a little more control of the CVT.
However, I found the paddle shifters work when in the selector is in the auto [D] position. Sometimes while in D, I hit the downshift paddle to shift into a lower gear to slow the car without using the brake. Especially helpful when you want to downshift quickly without taking your hands off the wheelor using the brake.
After downshifting, once you give it gas, it automatically returns to D.
117,000 miles and it hasn't hurt the transmission yet.
Old 06-27-2012, 10:02 AM
Tapani Tapani is offline
It's been done - , there are several out there.... one for an example:
http://www.ultimatesubaru.org/forum/...ad.php?t=93670
Tapani
Old 06-27-2012, 11:41 AM
Are the subaru style paddles attached to the steering wheel or the steering column? Do they turn with the wheel? The ones that turn with the wheel I can see being useful, the ones that are fixed (like the wife's lancer), I find very annoying. A friend has a mkv GTi, and those are small and attached to the back of the wheel. And very comfortable and intuitive I might add.
It would make me proud of subaru if they had done it the way that makes sense.
^ Good find tapani, that looks like pretty much exactly what he wants to do, on the same generation of 4eat.
Old 06-27-2012, 01:48 PM
The paddles are attached to the wheel and move with it. Very easy to control and and access. When holding the steering wheel, a little tap with you middle finger is all it takes.
When climbing a hill with the CVT, it is much easier to downshift with the paddle than to mash the gas.
Old 06-27-2012, 03:37 PM
crazyhorse's Avatar
Yeah, i know about the tcu flash method to create paddleshifted 4eat's. Thats not exactly a user friendly way to go about it. Like i said, im looking to make a plug-n-play setup. As for the tap and wait, the trans should respond quickly, and hold the gear regardless. It'll drive normally unless the paddles are turned on. What i need to know is if the trans is mechanically linked to the shifter in the lower gears, or not. Once i know that, i can decide if my method would be possible.
"42"
Old 06-28-2012, 11:56 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
another paddle shifted automatic?! is that really what we need? in my opinion, the whole point of a paddle shifter is changing gears quicker than the other methods, and in order to do that, i would very much rather switch between 3,2, and 1, so that it feels like a stick too(little bit?)
also the 4eat, or better say my 4eat, doesn't downshift under power...maybe you can get that to work...but I personally am not willing to ruin my SVX with paddle shifters
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 06-29-2012, 04:28 AM
Darren's Avatar
Darren Darren is offline
I looked at doing this a while ago, I actually bought a complete damaged JDM Legacy twin turbo RSK with the intention to keep the parts I needed after I has sold the engine and performance parts to a customer ( I think pics are in my locker still) I didn't go down the route in the end because my car is in excellent condition and I want to keep it factory standard.
It is do able if you buy a compete car and use everything you need from one source.
There is a post somewhere on the net of a guy who has put an eg33 into a 2 door Impreza with an RSK box and running gear with the paddle shift working. I remember talking to a guy at a show who was a Subaru tuner who said the running gear on the SVX and the JDM RSK Legacy is the same (also JDM Forester RS)
Do you guys get the 2.0 twin turbo Legacy in the US or just the 2.5 non turbo?
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 06-29-2012, 12:24 PM
Better yet, would the 5eat work with the SVX? Having had 3 4eat vehicles (SVX, and wife's WRX and FXT), i can say that the 4eat is a POS compared to the 5eat i had in the Legacy GT. I cringe when i have to drive the FXT - it just feels so ancient and crude.
I used to use the shifter for manual shifting, but the steering wheel controls were nice to gear down quickly in snow, or for slowing down to pass a cop without lighting up the brake lights.
I dont follow the technical forums here much anymore, so has s 5eat been thrown in an SVX yet?
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2005 Legacy GT (Silver) [Cobb Stg 2+] SOLD!
2005 Forester XT Premium (Crystal Gray Metallic) SOLD!
2008 Lancer Evolution X MR (Apex Silver) [Cobb Stg 1+]
2015 Outlander Sport 2.4GT AWD (Mercury Gray)
2013 G37xS (Obsidian Black)
