rear wheel wobbly
My right rear wheel is wobbling bad enough so that you can see it in the rear view mirror. Feels like it is ready to fall off.
I removed both rims yesterday, but can't really see, or feel, anything different between them. I can't move the wheel with my hands when the car is sitting still, but as soon as you start to drive it, the symptom re-occurs. I'm not at all familiar with this type of an axle. Could it be broken? |
Re: rear wheel wobbly
The wheel may be bent. I've seen many that have no obvious damage, but when spun on a balancer wobble like mad. Are you running stock wheels or aftermarket? If it isn't the wheel you may have a warped hub. My final guess would be that your wheel bearing has completely disintigrated, but that would include amazing amounts of noise. Put the car up on jackstands, put it in neutral, and spin the wheel by hand to see what it does.
Stop driving the car in the meantime.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 08-09-2008 at 02:54 PM. |
a broken axle would not be in the equation, The bearing in the hub supports the whole thing, Could a bearing be worn that much??? Could be warped hub.
I had a front hub warped from a big hole on the road. Good luck, Keith |
my typing speed always gets me there in second place!
Good advice, Crazy person! Keith |
keith, i would bet alot of money that you are spot on with the bearing. i had a saturn before my svx, the rear wheel sounded funny when i first bought it, over time it began to wiggle, oneringer, jack the car up, and see if you can push and pull the wheel from side to side, if so it is probably your bearings. i replaced the bearing assembly on my saturn (you HAD to replace the entire unit in saturns) and the problem was solved.
1992 silver/black LSL - 142,xxx miles power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler 1971 toyota landcruiser - project.... someday |
It could be the bearing, I guess. Definitely not a bent rim. It's not like it's bent, it's like it's falling off! How hard are the bearings to replace?
did you check the lug nuts?
Bearing's are either not bad or horrific depending on the car. Mine were a complete horror show, it took a 6' breaker bar to get some of the bolts loose. I don't know what sort of winter you get, but if they salt the roads you will be in for a rough time of it. If the underside of your car looks new, then it'll be an easier time. There are several how-to's all over this forum about replacing the rear bearings.
Do you get a loud noise from the rear when the car is driving? If the bearing is bad enough for the wheel to be wobbling around it would be roaring like a jet engine back there.
not real noisy
