Old 11-18-2006, 01:58 PM
Shadow_Myst Shadow_Myst is offline
Dissasembaly of dash
Hi everyone, I will be dissasembling my dash to change the lights on everything (from green/other colors to blue leds) Is there anywhere I can find a detailed diagram of the dash to know how to take it apart?
Thanks a lot
-=SM
Old 11-18-2006, 02:43 PM
The instrument panel removal instructions can be found in the How-To Documents here:
http://www.subaru-svx.net/photos/files/How-To/30457.pdf
Check this thread also: http://www.subaru-svx.net/forum/show...limate+control
The How-To Documents link is at the top right of the homepage. The climate control system is a little more complicated, but can be done. Once you get the instrument panel out, unscrew and take out the top/center air vent. Under that, there are 3 or so screws that hold on the climate control.
Before you take it out, you might have to take out the stereo as well. Instructions can be found here:
http://www.geocities.com/svxdc/AudioInstall-2.htm
There is a screw that holds onto the black trim piece. Then there are 2 more on the corners. That will take the stereo out. You now should be able to take out the climate control.
To take out the center gear shift piece, just yank it out..
