Old 12-26-2014, 05:57 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Failing aftermarket fuel pumps
I am going to try and find it tomorrow.
Tony
Old 12-26-2014, 06:51 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Originally Posted by Huskymaniac View Post
Guys, this sounded like the most likely culprit in my latest SVX saga. Drove the car home last Friday with no issues whatsoever. The next morning it wouldn't start. The starter ran and the engine turned over. I "think" I didn't hear the usual fuel pump noise. Should this be the first thing to check? If so, how do I get to this connector?
Tony
Spark, Fuel, Air ...
1. You've confirmed the engine turns over
2. Pull the fuel line from the fuel filter to the fuel rail -- crank and confirm that you've got fuel pressure
3. No fuel pressure - pull the back seat bottom and check to see if you're getting voltage at the pump when the key is on
4. Voltage good? yeah, replace the pump
5. No voltage? start back tracking the circuit
6. Good Fuel pressure at the fuel rail? start checking your sensors that will prevent correct spark events -- temp sensor, crank sensor, cam sensors -- you're looking for the correct resistance across each sensor. If you're lucky and can acquire them, replace them - one at a time - checking to see if it will start after each replacement.
Good luck with it!
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-27-2014, 12:02 AM
It's under the football shaped metal cover held in place with four phillips screws.
Old 12-28-2014, 12:51 PM
Be sure to check the ground side as well. Have seen a lot of fuel pumps fail from bad grounds. Increased physical resistance will cause higher amperage draw but increased electrical resistance will decrease amperage draw. A pump that draws too little burns out. Don't know why but it seems to happen.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 12-28-2014, 02:45 PM
Got it running again. Hopefully it stays running....
Tony
Old 12-28-2014, 04:53 PM
What cured it?
Old 12-28-2014, 08:56 PM
Not entirely sure. I cleaned the connector receptacle contacts. It was still not wanting to start. For some reason I told my kid to floor it and try one more time. It started and stayed running. I was able to start it a couple more times tonight with no issues. It idles great.
Tony
Old 12-28-2014, 09:32 PM
Sounds like the pump had to pressurize the system
