Old 08-10-2012, 02:52 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
Re: need help ASAP :(
Originally Posted by dragoontwo View Post
Tighten it if you can to get it home. Once there, take it off and inspect it.
i didnt have a wrench big enough to do that so i drove it very carefully back to work and it made there without a hitch...but i dont want to really drive it anymore...it did seem to not hit as much at some rpms though
Jared
1992 dark teal SVX LS
Old 08-10-2012, 02:57 PM
Green1995SVX's Avatar
Originally Posted by LastSVXintheChi View Post
ALSO the crank pulley is very loose to the point where it hits the block a little bit...now can i just tighten it or does it need to be replaced?
You cant tighten it. It's not the pulley itself that becomes loose, but the rubber bushing thing in the pulley separates so the outer ring of the pulley becomes loose, and the inner part stays put. You'll need to replace the pulley if that is, indeed, what your problem is. If it's actually loose from the crank, that's a whole other issue.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-10-2012, 03:22 PM
anyone have a cheap one thats not $140
Jared
Old 08-10-2012, 03:25 PM
http://www.subaru-svx.net/forum/showthread.php?t=60349
Old 08-10-2012, 03:40 PM
Originally Posted by Hocrest View Post
i cant believe that i just read the whole thread for the last 3 posts
Jared
Old 08-11-2012, 11:27 AM
oh and i forgot to mention i hit 150,000 miles while all this was happening
Jared
Old 08-15-2012, 07:57 PM
So I finally went to replace the crank pulley and it didnt need to be done it turns out it was just extremely loose...i took the belt off and it moved back and forth about 1/4 of inch...now what would make it become so loose?
Jared
Old 08-15-2012, 08:13 PM
Look at the woodruff key that holds the pulley in position on the crank and see whether it was damaged. If the pulley you got looks to be in better shape then swap it anyway.
Every time someone needs to change a crank pulley Harvey suggests some loctite stuff to put between the key and the keyway. Search and find out the kind of loctite and in your case I would definitely take the suggestion and use it so that the pulley doesn't have any play back and forth against the key. That might be why the bolt worked its way loose. And torque the bolt exactly to spec. I think the bolt is a 22mm head.
Old 08-15-2012, 09:10 PM
it was a 22mm...i didnt have a torque wrench and i was by myself so i tightened til the engine started to turn then i held the pulley and tried to tighten it as much as i could until it turned again...i dont know if that is good or bad...it was a 1/2 drive though if that helps
oh and mine was in slightly better shape
Jared
Old 08-15-2012, 09:32 PM
92 SVX 92 SVX is offline
It is not tight enough it does not take that much to turn the engine over.
there is a slot at the rear of the engine right in front of where the Trans connects you can put a heavy screw driver in to keep the engine from spinning it takes about 140 foot pounds i think
Old 08-16-2012, 05:39 AM
Blue or green lock tight do not use RED . Blue is common and the green is harder to find. Green is a gap filler, blue is a semi hard and red is
" I don't want to ever take it off with out a torch "
Do what you want but think before ever using red. This is 38 years
Of experience talking.
Old 08-16-2012, 07:47 AM
Conn ok
I mean it is pretty tight when I was holding the pulley still so that the engine wouldn't turn and tightening it I hurt the armi was tightening with.... I put most of my 220 on that 1/2 drive and was barely able to move it anymore...the engine didnt turn while I was doing this either... I had a real good grip on it
Jared
Old 08-16-2012, 09:46 AM
definitely gonna have to use some locktite cus its going loose again ill look at the key too
Jared
Old 08-16-2012, 10:36 AM
kwren's Avatar
kwren kwren is offline
I would use a large break-over bar and a mauler or a long box end wrench with a mauler to tighten that big old bolt. Not only would I, but I do. You are not going to twist that bolt off.
I learned my lesson with a 90 legacy wagon that to keep the warranty intact I had to have periodic maintenance and one required a timing belt replacement. Of course, The dealer had to do it... the big bucks people.
A few months later a "Ticking sound" developed. The pulley worked loose and damaged the key-way.
Being "cursed" with a logical mind, I decided that if I tightened the bolt enough... it would never come off again. Big old box-end wrench, or a break-over bar, and big old mauler! Makes sense to me.
Sorry about your situation
Keith
Old 08-16-2012, 10:39 AM
kwren's Avatar
Conn ok
Sorry, but using a 1/2 inch drive for that job is borderline laughable.
Keith
