Old 06-18-2012, 02:54 PM
Re: Some Troubleshooting help please
Yes there is, but as long as the reading the ECU gets is within the very wide range, it won't throw a code. If you disconnected it it would throw a code. If it's bad it very often won't, but can still cause symptoms. The ECU adjusts AFRs based on readings from this temp sensor, so if it's off by enough, then it could definitely cause this. It's also very easy to change, and available inexpensively from rockauto.
To back up this point, in my 92 silver, I was not completely sure what would cause some hesitation only during cooder weather (under 50*) and only for awhile before it got to operating temperatures. Never any trouble starting however and never a CEL. It wasn't until I had my 94 Laguna that I had similar drivability symptoms as well as hard starting and a CEL that came up with the Coolant temp sensor. I changed it out in my silver and haven't had the symptoms since.
I would suggest going with a Subaru part however. They're about the same price or cheaper compared to most aftermarket and never an issue with them. I, as well as others, have had issues with some of the aftermarket sensors.
Old 06-18-2012, 06:11 PM
I would go for the Temp sensor. The popping out the intake, is a lean mixture, so the temp reading must be off a bit.
Old 07-17-2012, 09:15 AM
Uncamitzi's Avatar
Member #447
This is the Temp Sensor at the top of the engine. Just abaft of the Alternator? and before (and below) the intake manifold?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-17-2012, 09:58 AM
Darren's Avatar
Darren Darren is offline
It sounds very similar to the problem I had on and off for months, it turned out to be the cam sensor on the side of the engine (not the top front one) it didn't throw a code until it was properly on it's last legs.
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 07-17-2012, 01:12 PM
johnboy615 johnboy615 is offline
Mine is the same, even after I changed the temperature sensor. I have found that on the very odd time that she doesn't startthat flooring the accelerator then cranking it will have it firing every time. Just something you might try rather than continually cranking.
Old 07-19-2012, 08:56 AM
Uncamitzi's Avatar
Member #447
For one week the car started normally. I took a short trip to Yellowstone on my motorcycle and when I came back the SVX started just fine for a day of going to the store and running errands. I let the car sit for two days and then nothing.. it just cranks...no pops, no stutters.... Nothing. This seems like more of a fuel or starter problem than the crank or temp sensor...but tomorrow I'm going to start to tear into it things... I'm going to check the fuel filter..the wiring to the sensors and the spark from stem to stern. Could this really be a crank or cam sensor problem?
I'll let you know when she's running again... in the mean time any input at all will be read and examined.
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-19-2012, 11:49 AM
Darren's Avatar
Mine would do the same...it would not start at all and when it did would run rough and cut out, other times it would start and run perfectly.
It didn't throw the cam sensor code until it finally refused to start at all.
Old 07-23-2012, 10:18 PM
Uncamitzi's Avatar
Member #447
Ok...first.... fuel pump is ok... and the fuel filter is not blocked... next...will be checking spark & ignition. I know you guys said it seem like a sensor...but... that just doesn't seem right with the symptoms .... but I've been wrong before.
It will just not start now...it cranks..but that's all..no pops, no kicks...
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-24-2012, 03:49 PM
Uncamitzi's Avatar
Member #447
so..... thinking back I hadn't checked for CEL codes....turns out it's throwing a
13 Cam angle sensor No signal from can angle sensor,
but signal from crank angle sensor 1
any way to check if the sensor is bad if the wiring shows continuity?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-24-2012, 05:29 PM
Thats the one on the side of the engine. Pull it out and see if there is any metal filings stuck on the surface. The book does not state any resistance checks for the sensors windings, but it should be more than 1k ohms.
There is a magnet in there, that may be too weak.
Old 07-24-2012, 08:50 PM
Uncamitzi's Avatar
Member #447
I found it..it's the one that I rewired during the water pump fix in the spring. Wonder if Subaru ever thought these would still be on the road 20 plus years after they launched.
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-25-2012, 03:58 PM
Darren's Avatar
That's the one I had to replace and I've had no problems at all since.
Old 07-27-2012, 08:54 AM
Uncamitzi's Avatar
Member #447
ok...here's another question to you knowing gentlemen and ladies.
I pulled the Crank Sensor off a parts car.... along with a temp sensor ..
Then I pulled the cam angle sensor off my car. The Crank angle sensor and the cam angle sensor look the same. fit interchangeably and have the same JECS A29-000-R00 stamped on them...the only difference seems to be the serial number stamped on the other side 1510 on the donor crank sensor and 3702 on my cam sensor...
Is there a difference? are they using the same sensor in both places?
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 07-27-2012, 10:03 AM
Yes, they are the same sensor, and are interchangeable.
Old 07-27-2012, 02:28 PM
Uncamitzi's Avatar
Member #447
looks like there's a bit of this going around....
http://www.subaru-svx.net/forum/show...915#post708915
Magnets are wearing out? (losing gauss) ... I guess... (see what I did there?)
Mitch Hansen
"uncamitzi"
This is a Dark Ride
