Solenoid C
Is there a write up on replacing solenoid C? If not, I am willing to make one when I replace mine. There are other things down there that should be replaced as well, so if anyone has a suggestion, I am all ears. I plan on replacing sol. C, the internal filter, the gasket for the pan, and my actual pan since it is dented. Anything else I should replace?
Re: Solenoid C
here is what was told to me |
Re: Solenoid C
I don't think there is a How-to on Sol C, but it has been asked about several times.
Re: Solenoid C
I for one would really appreciate a writeup of this!
I just had a used transmission put in my '92 (picked it up yesterday) and it has been giving the code '24' ever since! I did not think I had the capabilities or equipment to replace the whole transmission... but I do think a solenoid replacement may be possible for me. Have you thought of changing the transer plates also? I am not sure what it takes to do those, but I saw that as a recomendation if the 'Duty Solenoid C' had been a problem for a while? (I am still reasearching all this - any help is greatly appreciated!) Regards, Mitch
"It does have a little wang to it... Good though!" |
Re: Solenoid C
I am still doing research as well. But, since there is no write up I can find I will be sure to document the process, and submit it to earl. I am going to try and include any reasonable preventative maintenance while I an in there.
If anybody has tips or tricks that they would like to share, post them here or PM me. Much appreciated guys.
Re: Solenoid C
Okay, not all of this is necessary, but is basically the easiest process and most times, does not cause any issues with the exhaust no matter how old it is or if it's in the salt belt.
Drop the exhaust: Unbolt exhaust from hanger on rear of transmission, unbolt hangers from floor pans and unbolt the clamp that attaches the muffler to the exhaust piping. This allows the exhaust to hang down a bit enough to maneuver the needed parts out of the way. Unbolting at the spring bolt setup is also an option. Unbolt and remove heat shield Unbolt driveshaft from the rear diff flange-4 12mm nuts. Unbolt driveshaft carrier bearing from body and remove. (note, if you have the 2 piece driveshaft on your SVX, usually only in L AWD models, it may have a 2 piece driveshaft allowing you to unbolt at the flange just past the carrier bearing) Unbolt transmission crossmember from body, unbolt the crossmember from the transfer extension housing and remove (not completely necessary if only doing the C solenoid swap) Remove transfer extension housing bolts and also removing the exhaust hanger from the ext. housing helps as well. Using a 12" extension will help removing the top bolts on the transfer extension housing Using a screwdriver or something else to get in between the transmission case and the extension housing, carefully pry the extension off and get it a few inches away and then carefully unclip the C solendoid wiring "harness" and then pull the ext housing away with transfer clutches as well. Be careful to also make sure that the thrust and needle bearings do not get lost! That's the gist of it. Installation can be a little tricky since getting all of the transfer clutch discs/plates to line up can be tricky. Hope that helps, but doing it this way, it can be done even lying on the driveway with the car on jackstands. Maybe tomorrow I'll get pics up showing what a bad transfer clutch drum and thrust bearing looks like. A dead give away that there is a problem Last edited by 1986nate; 02-03-2011 at 12:17 AM. |
