Old 08-23-2007, 12:23 AM
94SubieSVX's Avatar
OOC for a while
Poopy, guess I'll have to keep looking
Wait, do you have the 80 series muffler? Because on Flowmaster's website they have single 2.5 in and dual 2.5 out. That's the only 80 series they have like that.
bLAh
Old 08-24-2007, 06:21 PM
processengr's Avatar
I like the dual outlet magnaflow tips on SVXEXCESS son's car pix. Do you remember what p/n that is ? There are several Magnaflow tips listed at Perfomance Peddlars where I am about to drop some $
If only OT would offer those prefab'd headpipes, i wouldn't have to depend on Monroe Muffler..
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-24-2007, 06:50 PM
I have the mandrel bent pipes, the AR20s, the Magnaflow two into one cats, and a stack of Magnaflow 2.5 in/2.5 out resonators HERE NOW!!!
Just SEND ME MONEY!!!
Old 08-24-2007, 07:59 PM
Highly recomended idea
Old 08-24-2007, 09:56 PM
I like the dual outlet Magnaflow tips on SVXCESS son's car pix. Do you remember what p/n that is ? There are several Magnaflow tips listed at Perfomance Peddlers where I am about to drop some $
The Magnaflow P/N is 35168. These are rolled dual angle cut tips made of double-walled, T-304 stainless steel. top notch manufacturing and finish all the way! (svxcess should know)
3" Dual Diameter, 2.25" I.D. Inlet, 10" Length
PerformancePeddler has them on sale for $51.69, but that price drops to $46.99 once you add them to your cart.
http://www.performancepeddler.com/de...CT_ID=MAG35168
Old 08-24-2007, 11:08 PM
94SubieSVX's Avatar
OOC for a while
The headpipes being the part with the O2 sensor bungs in them? If so how much
...bumped
bLAh
Old 09-04-2007, 09:40 PM
dizzan dizzan is offline
Obdii
What mods would be needed for the system you're all describing for an ODBII ('96) SVX???
Old 09-04-2007, 10:09 PM
simply get the magnaflow cat that has the bung for a 3rd 02 sensor
Old 09-04-2007, 10:20 PM
Cool. *adds new exhaust to list of projects*
Old 09-04-2007, 10:33 PM
The problem Tom (svxfiles) and I found with the Magnaflow 94037 cat (OBDII) was that the O2 sensor bung was located at the FRONT of the cat. The stock converter had the O2 sensor located at the REAR of the cat.
In the front location, the O2 sensor would not get as clean a reading. Plus the location makes it a real pain to get to if you need to replace the O2 sensor. See photo:
To solve these two problems on my 1996 OBDII Polo, We used a Magnaflow 94007 converter (exactly the same as the 94037, but without the third O2 bung
We then welded an O2 sensor bung into the side of the exhaust pipe, directly behind the converter. Cleaner reading at the rear of the converter and a lot easier to change if necessary. We did have to lengthen the O2 wiring to account for the increased length needed. We did this at the permanent wiring, not the O2 sensor wiring.
No problems whatsoever.
Old 09-05-2007, 06:14 AM
That sounds like a good idea. I like your setup - mind telling me what it cost??
Old 09-05-2007, 02:29 PM
94SubieSVX's Avatar
OOC for a while
I'll be buying the Cat, muffler, tips, and AR20 resonators tomorrow. Hopefully I can have this done before October
bLAh
Old 09-05-2007, 02:54 PM
Where are you buying from?
Old 09-05-2007, 04:43 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
True dual.
I've been contemplating my exhaust change aswell. I prefer the idea of a true dual and plan to have the same setup on my SVX as Impreza(will have EZ30D[R being 05+]) Which I submit for judgment. No main cat and replace the pre-cats with two Impreza cats probably Magnaflow ones. This runs back with no resonators through the two seperate pipes to Legacy GT muflers. Basicly with this I can more easily do it in stages. I'll see if I can get just the axle back of a Legacy GT set and 1-2 pipe into them till I can convert bit by bit. Then make up a dual pipe with flanges to link up to the Mufler in pipes and move the 1-2 to infront of the catback. Then after doing the cat swap out I have a true dual and a smooth flow. I have a 94 LSi so I dont have to worry about the third 02 sensor. Plus I have a system that I know either works or not for the Impreza aswell as the SVX. Comments? Suggestions? Utter N00Bism?
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 09-05-2007, 09:35 PM
94SubieSVX's Avatar
OOC for a while
Performance Peddler and ebay
bLAh
