Old 02-18-2021, 01:19 PM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Awesome! Stock rear?
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 03-15-2021, 12:43 AM
Re: Lsvx-t
Wow, going big! Good luck with the build.
Old 03-16-2021, 04:35 PM
Talking Re: Lsvx-t
Sorry haven't really been on the network in a bit. Pics of the latest developments. Making more progress but there's still plenty to do and even more to buy
[url=https://ibb.co/4MwmRB9]
Old 03-16-2021, 04:40 PM
Re: Lsvx-t
No I don't think the r160 would have made it far. It's an R200 in a full subframe and suspension out of a 350z
Old 04-02-2021, 01:04 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Re: Lsvx-t
I just randomly rejoined this forum after pondering an LS swap in an SVX and here this is. Good luck Tom, can't wait to see progress.
(you grabbed my svx back in 06/07 to do a 5MT swap while I was in Iraq)
Brian
Old 04-03-2021, 07:18 PM
Re: Lsvx-t
Hey man! Yea this has been lurking in my head for the last couple of years and I'm finally putting it together. I will say this, a 5mt swap is an absolute walk in the park compared to this lol. I have already made multiple variations of parts and configurations and then scrapped the idea and started over on several aspects of this project.
Update pics for those of you who are following. Said redos are listed in the pics. Nothing is set in stone. I might change it again before I'm happy with it lol
Old 04-04-2021, 05:08 PM
ZoraSVX ZoraSVX is offline
Re: Lsvx-t
Looking good! Can't wait to see the end result.
- Lenny
Current car: 2006 Saab 9-2x Aero, Midnight Black Mica, 180k miles, 5MT, mostly stock
Past car: 1995 Subaru Impreza wagon, EJ20G w/5MT, Koni Yellow inserts/STi wagon (GF) springs, swaybars, and other suspension goodies, STi seats
Future car: SVX, of course!
Old 04-04-2021, 07:50 PM
wdb wdb is offline
dances with roads
Re: Lsvx-t
Dang I missed the turbo mention. Beast in progress.
Old 04-05-2021, 03:57 PM
Re: Lsvx-t
What are the fittings you used for the steering rack? My lines are all corroded to hell and if I can replace them with -AN's that would be pretty sweet.
Old 04-06-2021, 04:30 PM
Re: Lsvx-t
They are generic 14 and 16mm iring fittings. Not sure if they will work with the svx rack. I'm running the quick ratio 15 sti rack. I've got a part# around somewhere
Old 04-10-2021, 04:58 PM
oab_au oab_au is offline
Re: Lsvx-t
Giday Tom, what box and rear end are you thinking of using behind that engine?
One Arm Bloke.
Tell it like it is!
Old 04-12-2021, 05:45 PM
Re: Lsvx-t
Tr6060 6 speed from 5th gen camaro. Currently going to run 350z r200 with axles and full suspension w/ spindles in the rear. Hoping it will hold up but if it breaks I am sure I can manage something on the back end pretty simply now that I have removed the factory fuel tank and have loads of room to work with. Good to hear from you Harvey
Old 04-12-2021, 08:19 PM
Re: Lsvx-t
Any weight targets? How does your motor/tranny compare to stock, weightwise? I recall hearing that LS motors are not that heavy.
- Lenny
Old 04-13-2021, 08:15 AM
Sean486 Sean486 is online now
Re: Lsvx-t
Is this build for the track only or will it be on the streets too?
Old 04-13-2021, 06:54 PM
Re: Lsvx-t
The engine is for sure about 80-100 lbs heavier but more than half of that is cut by the light weight transmission. So overall I would imagine an additional 60lbs heavier drivetrain wise. I might have lost weight in the rear of the car with the aluminum subframe from the Nissan. What's most important is that the engine is so much further back now that it's mostly behind the front axle which should help in the balance. I will get it weighed in eventually
