Old 04-30-2012, 08:21 PM
BackWoodsBob BackWoodsBob is offline
Re: CEL blinks these codes.
Finally indeed, been up on blocks for 3 weeks whilst trying to figure this mess out lol!
Bout time it moves under its own power.
Old 04-30-2012, 09:16 PM
Originally Posted by BackWoodsBob View Post
Ignitor wasn't the issue, turned out to be the guy that did the harness wired the crank sensors backwards, it runs!
Thank you Harvey for all your help and guidance!
Cost a vid!
And congrats. I know that feeling, that moment when after hours and hours of trying to figure out what's wrong, it finally roars to life. You almost stopped expecting it to altogether, but then that beautiful rumble that is life fireworks going off in your head, that you've finally succeeded. Feels good, man.
Old 04-30-2012, 11:06 PM
Actually I didn't realize that you were swapping into a different vehicle, just thought you were doing it to a SVX
Old 04-30-2012, 11:20 PM
Cost a vid!
Indeed, I was seriously doubting it would run at all. It has been almost 2 weeks worth of wiring an diagram reading to get this far! And lots of asking questions .
Yes this engine came from a guy who got it from a totaled SVX, so in a way I 'saved' it . If you look back I did link to my journal, if you go here there is a video of it running for the second time ever!
Thank you very much, without you I would be stonewalled as I can read wire diagrams about as well as a blind person. ( no offense to any blind people intended).
Old 05-01-2012, 12:10 AM
Sign of a job well done?
Hmm, I wonder if they have braille wiring diagrams...
Old 05-01-2012, 07:31 PM
bahaha, wouldn't do much good unless their wires were color coded in braille as well .
Old 05-01-2012, 07:48 PM
Mind = blown.
Old 05-01-2012, 09:59 PM
haha
filler text
Old 05-13-2012, 09:33 PM
Got it up and running and shifting through the gears!
I do have one question. What would cause it to feel gutless with more than half throttle? It just doesn't feel like it's making the power it should. Only codes are for Evap stuff that has been 'deleted'.
I am missing 1 vacuum line to something bolted to the xover coolant pipe. Would that cause what I'm feeling or?
Old 05-13-2012, 09:45 PM
redlightningsvx's Avatar
Collision Refinishing Tech
does the hose go to a black box behind the power steering pump?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-26-2012, 10:28 PM
Sorry just realized this was replied to.
I hooked all the vacuum lines up. I believe the gutless feeling was due to a limp home mode/misfire code that was present. Runs like a champ now .
usual low rpm hesitation. Solutions I'm pursuing are.
Impreza FPR
stand alone ignition coils from summit-racing for about 30$ per.
