4.44 Need Advice
I have a tranny, rear end and lots of help (thanks GreenMarine, lol) what else do I need to do the swap. Can I use stock shifter mechanism (lever). Also is the brake switch integrated with thrans, cuz mine is stuck. Thanks for the help
1992 SVX- -Drivetrain by BUDFREAK- Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now... 1997 Chevy 1500 -FOR SALE- 5.7 liter, Z71, 300hp+, still almost 20mpg 1986 Merkur XR4Ti -SOLD- SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever. |
The swap is VERY straight foward minus swapping the rear diff. You use all the same parts as the stock tranny. Your parking brake issue is something unrelated
Tom |
not the parking brake. The switch to shift when pressing the brake pedal
on a side note, i found some rims on ebay, stock R32 sized 16x6.5 5x114.3 +40 those should fit, right?
ok, 86 those wheels, but thanks for the responses
but what about my original problem with the trans lock?
1992 SVX- -Drivetrain by BUDFREAK- Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now... 1997 Chevy 1500 -FOR SALE- 5.7 liter, Z71, 300hp+, still almost 20mpg 1986 Merkur XR4Ti -SOLD- SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever. Last edited by hexadec0079; 09-29-2006 at 11:47 AM. |
So it will still be harder on the wheel bearings. But you still got me.
ok, children ,back on topic to the trans lock
OK, so when you have the key on, and push the brake pedal, do you hear a click at your shifter?
You should. And you should be able to feel the solenoid movement through the shifter. btw, do your brake lights work?
sounds like your shift lock computer is borked... they go out all the time, any suby shift lock "should" work but try to find one on the network, they are easy to come by from 5mt swaps
Tom |
