Old 08-18-2012, 02:09 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Oil leak
I have a 1992, and I've always had a little oil somewhere under my car, what should I expect for something almost 21 years old? Anyway, recently I started smelling burning oil, so I looked a little harder, and saw what seemed to be a significant amount of oil. The ground was dry where I park though, so all of the leak is being burnt off by the exhaust. My first inclination is the valve cover gaskets. How much is this repair? I have a reputable garage I know that knows the SVX and will do it right. I just want to know how long and how much for parts. Also, 2 and a half years ago, right when I bought the car I had to replace the ENTIRE cooling system, and while the shop had my engine out of my car, I had them replace every rubber gasket that they could reach while the engine was easily reached. I doubt it's something connected directly to the block, but as usual with this car, I'm probably wrong. Any likely culprits? I'm just going to carry oil with me and keep filling it up. Between oil changes (3,700 miles) I think I lost close to a half-quart to a quart. Not positive, as the mesurement cup only went to 4 quarts.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 08-18-2012, 11:25 PM
smc smc is offline
Re: Oil leak
Hmm. If its hitting your headers, then its most likely a valve cover gasket. First things first. Get a ratchet and socket, and make certain that all the cover bolts are snug. DO NOT torque the piss out of them, just good and snug. Then, get 2 cans of engine de-greaser. Drop your skid plate and take the car to your local self car wash with the high pressure washer. Soak every inch of your engine and front crossmember with the de-greaser. Allow to sit for 10 minutes. Pressure wash off and repeat with can #2. This should clean off your engine and allow you to pinpoint exactly where your leak is coming from if it reoccurs.
If worse comes to worse, valve cover gasket replacement is not that big of a deal. A good afternoon and basic tools will allow you to get the job done.
Old 08-20-2012, 09:47 AM
davew833 davew833 is offline
Re: Oil leak
Could also be the rear main seal or the oil separator plate on the back of the engine behind the flywheel. Subaru's updated the design of the separator plate several times because of cracking/leaking issues. It's not an expensive part, but reaching it requires pulling the engine or dropping the tranny.
davew833@yahoo.com
Former 6-time SVX owner
Old 08-20-2012, 03:16 PM
B 4 You's Avatar
#lolsvx
Re: Oil leak
Well I looked under it today. I took it to the car wash and just pressure washed the entire underside of it the other day to get rid of any oil I could. It seems to be wet only in the front. It's dripping into the "bowl" of the plastic cover that attaches to the bumper (can't think of what it's called), and dripping down the oil pan a little. Not that much. It seems idling it releases the most oil.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 08-20-2012, 06:50 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Re: Oil leak
Did you check your oil pressure sensor? It's right behind the power steering reservoir. Mine was leaking pretty bad.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 08-20-2012, 10:20 PM
B 4 You's Avatar
#lolsvx
Re: Oil leak
No, I'll have to check in the morning.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 08-22-2012, 12:16 AM
smc smc is offline
Re: Oil leak
There area a few screws and sensors to check on the top of the engine. But those will be obvious if leaking. Generally by pools of fluids on top of the block.
See if it looks like its coming out of the timing belt cover. If its dripping out of one side or the other, it may be the seal for one of the cam shafts.
Old 08-22-2012, 03:09 AM
Chris_'s Avatar
Chris_ Chris_ is offline
Re: Oil leak
Check this thread if it helps: http://www.subaru-svx.net/forum/show...419#post710419
svx my94 vtd EUDM
-custom Spax coilovers
Old 08-29-2012, 08:29 AM
tierod tierod is offline
Re: Oil leak
My 92 with 245 thousand kilometers on it developed a leak that at first glance looks tone a rear main or separater plate leak.
What I found however, was it turned out to be leaking from the air valve seal under the intake manifold (controls airflow inside manifold for high rpm)
Forget the proper name for this device.
It's apparently due to higher than normal blow by (tired engine)
I read about this somewhere but can't remember where.
To temporarily (untill engine rebuild planned soon) solve issue, and yes you can laugh, I used a one quart paint can purched from a paint store and ran pcv vent hose through the can before it went into intake. Then ran drain at bottom of can into crankcase (located under intake, rear middle) I also stuffed can with steel wool. I mounted can on pass side beside throttlebody.
No more leak.
Just something to check.
Cheers
Old 08-29-2012, 09:26 AM
Old Fogey
Re: Oil leak
No more leak.
Cheers
Steel wool and engine oil does not sound like a good combo to me. What is the intended purpose?
Glenn
Old 08-29-2012, 12:03 PM
Re: Oil leak
No more leak.
Cheers
So you made an air/oil separator? There shouldn't be enough blow-by in the EG33 to need one. I wonder what could be causing that.
