Old 09-28-2011, 12:44 PM
processengr's Avatar
Effect of bad IRIS checkvalve
Hi all,
I found the IRIS check valve on our 92 Ebony broken, wondering what effect this would have. Car is running well, except for slight hesitation right off of idle on very light throttle.
Taped it back together, but no change...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 09-28-2011, 05:25 PM
Re: Effect of bad IRIS checkvalve
You should be able to get another check valve at any auto parts store. Not having one is a vacuum leak whenever the IRIS solenoid is open. Plus, the vacuum tank not having vacuum due to no/bad check valve means that the IRIS butterfly won't be able to close, and the car will be lacking in low-end torque.
Old 09-28-2011, 05:36 PM
Originally Posted by processengr View Post
Hi all,
Hi Gordon, If broken, as in no connection, or broken as in won't hold vacuume in the tank, then the IRIS butterfly won't close for the Inertia system to work, and you will not have that good torque from 2200 to 4000, it wll just be in the Resonate system all the time to work from 4000 up..
