Old 07-22-2012, 12:21 PM
Re: SVX Won't Start... Fuel Pump?
have you tried checking codes?
Old 07-22-2012, 12:37 PM
showoval showoval is offline
Doh! No I haven't, gonna have to search here on how to do that.
01- Impreza RS Original Owner
92- SVX LS-L
Old 07-22-2012, 01:21 PM
http://www.subaru-svx.net/forum/atta...7&d=1342909427
Here ya go, assuming the link works normally.
Old 07-22-2012, 01:38 PM
kwren's Avatar
kwren kwren is offline
Works like a dream!
Saved and very appreciative... Thanks,
Keith
Old 07-22-2012, 03:39 PM
Thanks for the link! I'll go back to car later this afternoon when it cools down a bit, it's like a sauna out there.
92- SVX LS-L
Old 07-24-2012, 10:16 AM
Pulled an 11 crank angle sensor 1 and 37 o2 l/h sensor. From what I've read on here in a couple of threads looks like it won't start if the crank sensor 1 is bad. So I now need to find one.
92- SVX LS-L
Old 07-24-2012, 10:30 AM
Pull it out and check if its dirty before you go replacing it. Also check the wiring to it.
Old 07-24-2012, 11:02 AM
If looking at the alternator, which sensor will it be the left or right. Not sure of the correct lingo crank or cam sensor
http://www.subaru-svx.net/forum/show...67&postcount=2
92- SVX LS-L
Old 07-24-2012, 11:04 AM
Thanks for info, will do but which one do I pull out"
92- SVX LS-L
Old 07-24-2012, 11:26 AM
Crank angle sensor 1 is the one with the 90 degree bend. Meaning the plug and bolt make a 90 degree angle. It is the one on the left, looking at it from the front.
Old 07-24-2012, 12:28 PM
Thanks for all your help so far 88, appreciate it. Will check tomorrow before work.
92- SVX LS-L
Old 07-25-2012, 10:12 AM
Pulled the sensor, it looked fairly clean, had a little grime on it but for the most part it was pretty clean and shiny. I looked at the wiring, the shroud was a little brittle and cracked in one area and a little of the ground shield was exposed but the wires near the plug felt pliable. So put it back together and no go, so I guess the sensor has given up.
Just realized that I should've checked continuity of the wiring prior to putting it all back together...crap
92- SVX LS-L
Old 07-27-2012, 12:24 PM
Got a brand new crank sensor from Subaru, installed it and sure enough, she fired right up! Thanks guys for all the help with my dilemma, I really do appreciate the help.
92- SVX LS-L
