Old 12-21-2008, 03:55 PM
Sanosuke's Avatar
Sanosuke Sanosuke is offline
Found a lost SVX
Alternators?!
I am now on my third alternator, second in four months. I understand they do not make new alternators for our SVXs. I asked a master Subaru tech if there were any alternators from other cars that fit the SVX and he said he had no idea. Is there a reliable way to fix a problem like this, where the refurbished alternators fail? Are there any crossover alternators?
Could bad wires of some sort cause a new alternator to fail? How would I check?
:..Miharu..:(1994) Laguna Blue SVX 170k. MODs: Beat to shjt.
:..Fey..:2005 World Rally Blue Impreza WRX 80k and rising. MODs: Lowering springs, 22mm sway bars. SS brake lines.
Old 12-21-2008, 09:26 PM
stiguy's Avatar
stiguy stiguy is offline
Re: Alternators?!
the svx i just got has a new alternator fron kragen autoparts even has a lifetime warntey
Old 12-21-2008, 09:29 PM
kwren's Avatar
kwren kwren is offline
Re: Alternators?!
same here ................
Old 12-21-2008, 10:19 PM
Re: Alternators?!
My AC Delco reman is also lifetime warranteed. Spend a few extra dollars now, and don't worry about having to spend them later.
Old 12-21-2008, 11:34 PM
Sanosuke's Avatar
Found a lost SVX
Re: Alternators?!
Thanks, I was completely relaying on this tech for info on this and he apparently had no clue.
Thanks again.
Old 12-22-2008, 05:52 AM
dcarrb dcarrb is offline
Re: Alternators?!
I'd be extremely surprised if any "new" aftermarket alternator for the SVX isn't actually a reman.
dcb
Old 12-22-2008, 09:13 AM
Sanosuke's Avatar
Found a lost SVX
Re: Alternators?!
I need to drive this car 2300 miles from PA to AZ. I hope this alternator does not poop out on me.
Is there an easy way to check the wires for damage or weak points? The grounds seem fine could they go bad?
Old 12-22-2008, 01:35 PM
kwren's Avatar
Re: Alternators?!
You can pretty much visually check your main cables and such but we have no way to know when the internal components of the alternator will fail... until it happens.
With the exception of erratic behavior, which we are pretty much given a rude awakening, it works or it gives us the Christmas tree thingy! Basically they work or they don't
If a in doubt, I would bite the bullet and just replace it for that long trip. Lots of things can happen nowadays when we get stranded in God only knows where, and none of them are good.
Take care,
Keith
Old 12-22-2008, 04:57 PM
processengr's Avatar
Re: Alternators?!
This is a thread on the state of the art in SVX alternators....
http://www.subaru-svx.net/forum/show...ger+alternator
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 12-22-2008, 08:31 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Alternators?!
Bring your car to a PEP BOYS or AUTO ZONE for a battery and alternator test.
Old 12-23-2008, 08:12 PM
stiguy's Avatar
Re: Alternators?!
just by one take it with you and the needed tools. and then if you don't need it return it when you get back.
