4.11 swap - aftermath
Well, my mechanic buttoned up the car yesterday and I took her out driving. Everything seems fine, no binding around corners, FIRM shifts compared to my slipping stockbox, and ACCELERATION
![]() (your money order is on its way Tom) Seems I'm having one issue: when letting hammering the gas or letting off the gas at highway speeds, there is a loud rattle coming from the center of the car. Im HOPING its just loose exhaust shields... thoughts?
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
that or a bed resonator
Tom |
Its a REALLY noticeable scraping/grinding rattle, if it helps, it also does it as soon as I turn the key to start her up
If not the heat shields it COULD be the Torque Converter bolts being loose. They make ugly noises. They're also not a huge deal to check.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
how should i got about checking them? pictures or diagrams would help.
my mechanic reused the torque convertor from the 4.11 trans... is that going to be a problem down the road? or will it be fine if I don't romp the car
or a bad flex plate... i would check the bolts though
Tom |
yea well on the highway things finally went - the car just started revving freely, and then wouldnt start at all, when i turned the key something would spin but no click... took it back to the shop and he said he will tighten up the flywheel bolts
my guess is that your flexplate actually came loose from the TC
![]() ![]() -Bill p.s. you can see the flexplate bolts through the access hole at the top of the passenger's side of the engine -- there may or may not be a rubber stopper in the hole.
would it be normal for some trans fluid to leak during this process?
-Bill
Another possibility is that a cracked flexplate completely separated...
Where there any harsh noises when you lost power? How much fluid are you talking about????
no horrible noises, i shifted down to 2 and it 'caught' for a few seconds and held power but then revved freely again. Not much fluid, probably half a quart at most
take a look through the access hole and see if you can see the flexplate
![]() Bill
![]() You should ONLY use SVX torque converters, or 4,44 torque converters, and THOSE only with 4.44 transmissions.
Ya know, i am not very far at all and usually I can tell you what it is upon the first inspection. I wish you would have brought it here in the first place
Tom |
