Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 04-23-2007, 01:08 PM
longassname's Avatar
Just some dude.
ECUtune SVX pistons
We've gotten in the first batch of custom SVX pistons so it's time to start this thread. This piston design is now established for us so we can offer them as individual sets. They will be made available on our website when I revise it for multitude of performance hardware options we are developing (pistons, cam sets, rods, transmissions, forced induction parts); except for the forced induction parts, the other performance parts allready have their own threads.
Price $1090 shipping $30 lead time 5 weeks
highlights:
compression ratio: 8.5
pins: tool steel
valve reliefs: -0.275"
anti detonation grooves
Description: These are forged pistons designed for use with either gasoline or E85 and boost levels up to and in the 30's psi range. They are machined from the strongest forgings possible with emphasis being placed on strength. Appropriate rings are included and optimum ring placement for the application was incorporated into the design. Latteral gas porting was incorporated to facilitate sealing of extreme cyllinder pressures. Tool steel pins were used for maximum strength. Pins are centered as this is better for higher cyllinder pressures. Piston tops are designed for optimum squish area performance, intake charge mix, charge to spark kernel pressentation, flame propagation, and expansion force application.
I'll follow this post with some pictures and some notes trying to illustrate the features.
Old 04-23-2007, 01:40 PM
Just some dude.
Stack of the 1st seven sets. These are all spoken for not stock.
1 boxed set open
the boxes of rings and tool steel pins opened
bottom/inside of piston note the holes that allow the oil from the oil control rings to pass through--obviously much stronger than the factory slots which were prone to failure.
note the grooves for the Subaru Tru Arc pinston pin circlips
note the the oil dispersion grooves on the pin oilers
note the deep valve reliefs which maintain zero interference with high lift camsafts
note the symetry of the piston top
note the flat top matching the cyllinder head squish area
note the anti detonation grooves
note the deep ring placement
note the latteral gas porting on the top compression ring
Old 04-23-2007, 01:43 PM
RSVX RSVX is offline
Network Design Administrator
Note the sheer awesome-ness of this thread...
Life is a game. Play to win.
Old 04-23-2007, 02:00 PM
92svxinmn 92svxinmn is offline
Do you know the weights of the pistons and the weight of the pins? are they lighter then stock? Cool but I'll have to wait for awhile on a set. Still machining deck insert to close the deck on my block.
Old 04-23-2007, 02:13 PM
sicksubie's Avatar
Which box is mine, which box is mine??? Those are awesome. They can withstand up to 30psi you said, but what is the peak boost that we will safely be able to run on pump gas? I think you might have said what it was on the phone (15psi I think) but I am not sure.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Just some dude.
pistons are 419 grams. I think the pins are around 120 grams.
the forged piston complete with tool steel pin is about two ounces lighter than the factory piston and factory pin
Old 04-23-2007, 02:14 PM
sicksubie's Avatar
BTW any news on the rods? You said that you were going to match the pistons and rods into sets before you shipped them to me right?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 04-23-2007, 02:20 PM
Just some dude.
no news on the rods yet. I'm going to go ahead and ship the pistons out. I don't want to hold onto all these while I wait for the rods.
Old 04-23-2007, 03:24 PM
mikecg's Avatar
mikecg mikecg is offline
Mmmmmmm, yummy......
Old 04-23-2007, 03:32 PM
soooo nice and shiney...
Old 04-23-2007, 03:46 PM
looks like I will need to call that machine shop sooner than later eh?
tom
Old 04-23-2007, 03:49 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
omfg i gotta start saving....these are way to shiny to resist
[SIGPIC][/SIGPIC]
Old 04-23-2007, 04:25 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
oh beautiful and shiny
looks like SVXi can withstand more boosts and be even faster...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 04-23-2007, 07:02 PM
JaySVX's Avatar
JaySVX JaySVX is offline
Yet again, my wishlist grows even longer...
Congrats, very nice looking. What kind of abuse can stock rods take, as TomSVX i believe shattered his piston on his one car, not the rod. Could the rods take up to 15psi without worry, as long as the pistons can?
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-23-2007, 07:06 PM
I think the rods and bearing are good to at least 500 hp. Just don't **** it up
tom
