Old 06-09-2006, 06:15 AM
down under down under is offline
central clunk very costly help please
I have a clunk which no one can solve. On accleration from rest and when turning right from rest i get a clunking and banging which comes from under the centre consol. I have had the drive shaft out and balanced, replaced exhaust system, had gearbox out and had faulty bearing replaced in torque converter, checked engine and gearbox mounts etc etc and lots of $'s later clunk and bang still there!!!! It is possibly a minor problem but no one can solve it and now i am getting frantic. I have also replaced motor due to a major overheating problem so i cannot think of any other possible problem. My car is a 1994 with 200000km but current motor and g/box less than 500000klms. Has anyone any ideas please?
Old 06-09-2006, 10:48 AM
Has anyone looked at the front differential?
Old 06-09-2006, 11:11 AM
Rear trans mount broken
Front trans mount loose.
Old 06-09-2006, 05:33 PM
yes to all
the gearbox has just been out to fix torque converter all mountings were checked engine and gearbox. Diffs front and rear have been checked and they are fine. It is not that sort of problem as it is not a binding type issue or noise related. Car drives extremely well with no other issues just a thumping coming up under centre consul and a soft cracking noise but not cv joint type noise more like a rubber dampened noise. I may have to mount a video camera under neath and go for a drive as it is impossible to replicate this problem on a hoist as it only happens under load. But i sure would like to no the answer as it is spoiling the joy of driving the car.
Old 06-10-2006, 12:22 AM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
Had exactly the same problem. Replaced the drive shaft centre bearing, Part No: 27037PA000. Problem gone.
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
Old 06-10-2006, 12:42 AM
Others please excuse OT. How are things down your way ?
Old 06-10-2006, 07:25 AM
JDW-SVX's Avatar
JDW-SVX JDW-SVX is offline
it's ruby red - not burgundy!!
How were you able to do that? I have checked my driveshaft, and the centre bearing cannot be separated from the rest of the shaft!
Jason.
1992 Charcoal Grey SVX - 165,000km
1992 Ruby Red SVX - 165,000km
....now with sequential VIN numbers!
1986 Holden (Isuzu) Piazza Turbo - 225,000km
1993 Mercedes W140 S500 Coupe - 153,000km
1990 Mercedes W124 300D - 313,000km
EG33 + 4EAT + VTD AWD = SVX
Old 06-10-2006, 04:12 PM
paddlesnz's Avatar
On the JDM models, there were two types of driveshafts. The 4WS model used a driveshaft on which the centre bearing couldn't be replaced separately. Other models used one on which the centre bearing could be replaced.
Australian models used the same driveshaft as the JDM 4WS model then???
paddlesnz
1999 Mazda Astina
2006 Honda Legend
2007 Toyota bB
Old 06-10-2006, 04:35 PM
JDW-SVX's Avatar
Interesting - why would they use two types of driveshafts?
After all, the transmissions and rear differentials would be the same!
I have now found out that two different types of driveshafts were used (at least on US models) - one uses a central CV joint, the other uses a central universal joint. It is this second type that has a replaceable centre bearing.
Which type of driveshaft do you have?
Jason.
