Old 10-12-2005, 10:31 PM
davew833 davew833 is offline
Head Gaskets: To Mill or not to Mill?
I'm contemplating doing the (leaky) head gaskets on my '92 pearl. Assuming the heads aren't warped and are perfectly flat, is it a good idea to machine them or not? I've been told that machining increases the compression ratio, putting greater strain on the bottom end, and causing excessive oil consumption and/or engine failure. The engine has 160k but has been well maintained, runs fine (except for the head gasket issues), and uses no oil at this point.
I'm aware the 'ideal' solution would be to replace the engine with a nice low-mileage unit, or do a complete rebuild, etc, etc...
Old 10-13-2005, 08:25 AM
According to Subaru, the max head milling allowed is (0.30mm) 0.0118"
With a bore of (96.9mm) 3.815" that only takes away .809304 cid.
Since our engines are 202.46 cid, at the stock 10 to 1 compression ratio that gives 20.246 cid in the head and head gasket volume.
Dropping the head volume down to 19.436696 only raises the compression ratio to 10.416379to 1.
And would slightly retard the timing.
I believe a bump in compression is a good power builder, and that our engines can handle it, but a thinner head gasket might be better. Tom
Old 10-13-2005, 08:56 AM
The eg33 block has a grinding limit of 0.016".
Milling that off the block loses 1.0973616 cid.
With both the heads and the block milled to the factory max that gives 18.339335 combustion cid, or an 11.039658 to 1 compression ratio, with the stock head gaskets!
The maximum overbore allowed by Subaru is 0.020".
This would give 204.453 cid. Not a huge differance.
Cut the compression goes up to 11.148332 to 1.
Every little bit helps.
Old 10-13-2005, 10:35 AM
shotgunslade's Avatar
So, how would milling the block and heads affect the non-interference (valve and block only, exhaust and intake valves can interfere) characteristic of the engine. Also , do you think there would be a problem with an intake cam with 8mm lift instead of 7mm.
Old 10-13-2005, 10:42 AM
Get the heads milled.... With a leaky HG you can easy overheat the engine with air pockets in the coolant. This will warp the head if it not already. I did not mill the heads on my old when doing the HG and payed the price of wasting my time Mill the head and get a thicker HG to keep the engine at stock specs... Maybe one of the copper ones that talk is floating around about
Old 10-13-2005, 10:59 AM
Subaru is telling us, that it's OK to shave 0.30mm off the heads, and 0.40mm off the block in their factory service manual.
Thats 0.70mm combined, and Subaru would not allow that if it made our engine an interference engine, rather than a non-interference engine.
The second question is harder to answer.
If you are only installing a higher lift cam, without shaving the head and/or block, then sure 8mm will be fine.
The pistons have valve reliefs, and the valves do not go strait up and down, they are at an angle to the piston, making their vertical travel less than 1 extra mm.
Of course, if you take your engine apart, you can check the clearances with clay.
If anyone does this, please report back to the rest of us.
Thanks, Tom
Old 10-13-2005, 11:21 AM
I also realize that the intake valves will not yet be fully open when the piston is at TDC, so the question is really academic, unless you break a timing belt.
Old 10-13-2005, 11:47 AM
Shotgun, your signature lists an ECU tune stage 2V4.
Do you have it installed yet?
Old 10-13-2005, 11:55 AM
Yes. I do. Even had it out on the track. I haven't noticed that much difference with the Stage1v4. They both really change the character of the SVX throttle response. However, with some upcoming mods to improve breathing and installation of an Impreza FPR, I think the Stage 2 chip has a lot more potential.
Can you take a look at my thread in this forum concerning error codes. Wondering if you had some thoughts on that.
Old 10-13-2005, 12:04 PM
I got one from Michael, but do not yet have a Z32 maf. I am hoping for a big differance, as I am maxing out my stock maf, I believe.
8psi will do that!
