Old 11-25-2004, 10:21 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally posted by sicksubie
What is tps?
The thottle position sensor. The factory setting should be 0.50 volts.
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-27-2004, 11:15 PM
sicksubie's Avatar
Does adjusting it accomplish anything? If so how do you adjust it?
Old 11-28-2004, 01:52 PM
It is used as a referance by the ECU and the TCU. Without it's proper referance, your transmission can slip or hunt for gears, and your engine will not perform correctly.
To adjust the TPS, first locate it on the drivers side of the throttle body. It is black, 1.50" round, and attached with two screws. Find the white wire, splice a test lead into it. With the engine running, and all electrical stuff off, test the voltage, between the white wire and ground. Adjust it to .50 Volts.
Old 11-28-2004, 05:18 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
adjustment coming from loosening the two screws and physically turning the black housing until your voltmeter reads out .5 VDC, then you tighten the two screws.
-Bill (it's true! I watched Tom do it! )
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-28-2004, 08:45 PM
Chiketkd's Avatar
Me too!
-Chike
Old 05-28-2005, 10:08 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
Originally Posted by svxfiles
Driving like a raped ape on the highway (90-110mph), Svxfiles gets about 19.5mpg in his 4.44 geared SVX.
Sir, I most heartily dissagree. It was 85-105, and we actually got 21.9 mpg.
Closed course, professional driver, do not try this at home boys and girls.
Tom, its Dayle in Tucson
if you get a chance, can you email me ?
dayle@motorsportwarehouse.com
thanks
me
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 05-29-2005, 01:27 AM
NeedForSpeed NeedForSpeed is offline
I think Chike was closest to the truth. Both 4.11 and 4.44 gears have the same third and forth gear. So, the 4.44 with its lower first and second gears may get a better start, but the 4.44 is handicapped by a bigger spread between second and the 1:1 third gear.
The 4.11 has the same gear ratios as the stock box, just with a 4.11 to multiply each gear instead of the stock 3.45. In the end, equal power, both probably run very close to the same time in a quarter.
The place to check the difference in the effect of the better multiples offered by the 4.44 is at the 1/8 mile mark.
Originally Posted by SVXRide
Everything else being equal, the 4:44 will accelerate faster - which should result in a faster 1/4 mile time (guess we'll see this weekend - right Tom/Chike?).
-Bill
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-29-2005, 01:31 AM
In a conversation with SVXfiles, I mentioned that I believed he would have a better run with stock diameter tires and 4.44 gears. I thought the smaller diameter tires [even lower effective gear] were running the engine past its power peak at the end of the quarter mile, and in effect, just hanging on for the end of the run.
I was very recently suprised that my two inch shorter tires (205/40/16s) gave a slightly slower speed in my G-tech 1/4 mile runs, compared to my 225/45/17s. The only explanation that I can figure is that the 17s weighed 3.5 lbs per wheel LESS than the stoch 20 lb wheels. The tires weighed the same. Tom
Old 05-29-2005, 07:11 AM
Chiketkd's Avatar
Ron,
after having both 4.11's and 4.44's on my car, I'd say this:
4.44's are going to shoot you off the line (like a bat-out-o'-hell) and the car will scream through the first two gears in next to no time. Once the shift into third occurs, my 4.44 svx doesn't feel like it's pulling any harder than my 4.11's did in that same gear (probably due to the larger spread between the 2nd and 3rd gear ratios).
I'd probably estimate that 4.44's are between .1-.2 seconds faster than 4.11's in the 1/4 mile (due to the shorter 1st wo gears).
I'd also say that 4.11's are probably .1-.2 faster than the stock 3.55 gears.
Therefore, someone like Bwana who ran 15.37 @ 89 in his lightly modded stock geared SVX, would probably run a 15.0 like I did if he switched to 4.44's (and maybe a 15.2 if he switched to 4.11's).
Just my $0.02...
-Chike
P.S. The gain from switching to 4.11's and 4.44's could be greater but I haven't had the opportunity to race my SVX in similar 40* temps like Bwana did. A 4.11 geared lightly-modded SVX could possibly run a 15.0 in the 1/4 in perfect conditions, and a 4.44 geared SVX could be in the 14.8 range in cooler temps.
Old 05-30-2005, 11:06 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
may i add that my car does a 4 wheel burn out with 4.44's.......yes it was a little rainy but still. thats some good mojo right there.
Old 05-31-2005, 10:47 AM
Yeeaahhh baby, yeah.
Old 05-31-2005, 11:06 AM
123456789 lol
Old 05-31-2005, 12:49 PM
i adjusted my tps reports after I got the memo
Old 06-01-2005, 11:46 AM
are you going to eat that stapler? want to split it?
Old 06-02-2005, 03:17 PM
sicksubie's Avatar
What is this about stapler eating?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
