Old 05-24-2005, 09:41 PM
1992SVX 1992SVX is offline
pcv valve
does it have one. if it does where is it
Old 05-24-2005, 09:47 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Wink
it has one. you take off the black plastic cover that runs down the middle off the intake. theres a little hole there where you'll see the pcv valve screwed in to the underside of the intake upside down. the best way to get it is with a crows foot. i believe theres a how to in the how to locker.
Old 05-24-2005, 10:42 PM
Amazing what someone can find it the "How-To Documents"! Here is the How-To on PCV Valve Replacement. Good luck.
Old 05-25-2005, 10:29 AM
thanks for the help. just found the how to locker after my last post.
once again thanks for the help
Old 05-25-2005, 10:37 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You can check my locker for addition pics on the use of duct tape and the crow's foot. Remember to set the rachet wrench as if you were tightening a bolt since the PCV threads "up" into the intake.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-25-2005, 12:18 PM
KCROGUEDOG
what happens when bad and does it set a ce light for a warning.
Old 05-25-2005, 12:25 PM
SVXRide's Avatar
I don't think you'll get a code....just oily film all over the back of the top of the engine
-Bill
Old 05-25-2005, 12:26 PM
Earthworm's Avatar
Meow!
If it's bad your crankcase will build up pressure and possibly push out or cause seals to leak. A telltale sign is your engine oil dipstick will keep pushing up after running.
There will be no CEL to indicate any issues with the PCV valve.
Old 05-26-2005, 02:57 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Until it burns enough oil to set O2 sensor codes. Which may take a while...
Old 05-27-2005, 06:55 AM
Budfreak's Avatar
Banned
and if you take the intake piping off the throttle body you'll probally notice a fair amount of oil in the intake tract.mine would actually drip from the throttle body!
Old 05-27-2005, 04:58 PM
ThetaReactor
I was able to get mine out with a flex-head gear wrench. It takes a little more effort, because you're exerting torque perpindicular to the nut, but it works. The metric set of 'em is about $20 more than a set of crow's-feet, but I'm constantly finding handy uses for the wrenches. Just used the 17mm to change the oil last night.
