Old 01-18-2010, 11:31 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Cam question
I haven't even considered doing a cam regrind for a while now cause frankly I don't have the extra 800 dollars laying around to do it. However today I was thinking about it and I believe I read (and I'm going from memory here) that the weak side was our exhaust cams, so I was wondering about getting just those two done. Think that would do anything noticeable? If so, recommend me a profile. From memory (again) I remember something like 8 mm of lift, 118 duration if your running a 3.90 manual like I will be?
Old 01-18-2010, 08:10 PM
Trevor's Avatar
Trevor Trevor is offline
Re: Cam question
If so why start a special thread on the subject?
You are calling on others (with out a "please"), to relieve you of a little effort searching. The subject has been fully covered in several threads and it is clear that you are very aware of this fact.
I make no excuses for my terse response. The technical section is becoming a dogs breakfast.
Trevor, New Zealand.
Old 01-18-2010, 10:19 PM
Re: Cam question
There are a number of profiles that have been tried with success. Chike describes one he used in this thread. ECUTune also sells a few profiles designed to work with different engine setups. I know Delta and Web cams have also been used, but I don't know the details or if they were a custom grind.
Old 01-19-2010, 08:41 AM
Re: Cam question
Glad to see your kindness is not limited to just the over heating thread.
In other news I believe I was confused, from the thread you posted they're talking about doing the intake cams alone. I suppose I was thinking about rallybob matching the exhaust ports with the intake ports, not the cams.
