Old 07-24-2013, 09:35 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Main catalytic convertor help...
Originally Posted by fasteract7 View Post
Could you mean 2.25" OD to 2.5" ID adaptor..? 2.25" OD would slip inside stock 2.36" ID pipe leaving 2.5" ID to fit AR25...?
Thanks
Yes, 2.25" OD to 2.5" ID is what I meant. It gets confusing sometimes.
Anyways, when you're working with ANY stock exhaust make sure to measure over 9000 times and buy parts only once!
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 07-25-2013, 01:52 AM
Alex-svx's Avatar
Alex-svx Alex-svx is offline
No. They are AeroTurbine AR20 resonators. They can be used to replace the original pre-cats in the 1992-1995 OBDI cars without problems. No CEL, etc.
They do not work well on OBDII cars; the system is more sensitive and needed pre-cats to keep the CEL off. After these photos were taken, I removed the resonators and replaced them with small Magnaflow converters. No problems since.
Magnaflow 99204HM
Ok thanks.
Alexander (Norway)
My subarus:
1992 Svx LSI 5-MT(3.54)
1998 Legacy BG 2.5L GX
Old 07-25-2013, 12:07 PM
bishop bishop is offline
In an OBDI car is it ok to remove the pre-cats all together or do they need to have something else put in place?
Old 07-25-2013, 03:08 PM
If you remove the pre-cats (or the main cat), it won't trigger a CEL. But you may not pass a real-life emissions test, if your state does them.
