Antenna
My antenna is bent and I was going to try to fix it. I got the mast out just fine, but now I can't figure out how to get the darn thing back in. Has anyone else out there tried to fix a bent antenna? How do you get them out/in. has anyone upgraded their antenna, and how would you go about doing that?
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit. Next changes ... PAINT, fix engine problems, 4.44. (GONE) '97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE) |
I had the same problem and gave up. There is a way to separate the antenna from the motor, but I left that to a Subaru mechanic. I believe there are some threads in the archives on this.
I did replace mine and in hind site I should have not bothered and just put in one of the new stealth antennas used to retrofit classic cars that mount under the package shelf or some other inconspicuous place |
Everything you need to know about the removal, disassembly and reassembly of the antenna can be found HERE or HERE Just your bent antenna mast can be replaced (#4 in the diagram) for $46.84. Known as the Rod Assembly, the PN is 86322PA010 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-03-2007 at 12:22 AM. |
I had one of those "hidden" antennas and it did not work well anywhere inconspicuous. It was a good one but once hidden it would lose most of its reception. I tried probably a dozen or so locations in the car with similar results. Does anyone know how good the stock rear glass antenna works compared with the power antenna? If its decent that may be another choice.
1992 LS-L Liquid Silver (# 7,083). |
The stock antennas work fine.
I thought that both the rear window antenna and the power were always connected at the same time. When my power one broke I did manage to jamb it down most of the way and reception was awful.
cut off antenna, get sirius/xm, live happily ever after.
Brian |
Think twice about trying to reuse that old mast, or any sort of "upgrade." dcb |
