What tools to buy
It might just be a brief moment of macho overestimation of my skill, but I'm thinking I should be able to tackle my timing job, valve cover gaskets, and a more in depth tuneup for plugs and PCV valve.
The only problem is that I have a cheap socket set (and by set, I mean cardboard box of random sockets with all of the 10mm missing anytime I need one). I'm planning on the full timing job, so all the idlers, the hydraulic tensioner, water pump, and seals. I figure I'll need: - Decent metric set. 22ish mm for the crank pulley. Probably regular and deep well - Torque Wrench that'll handle the torque of said crank pulley. - Gear/pulley puller - Extensions and universals - Mechanics gloves - Jack and stands - my body weight in oil dry Anything I'm missing that can make this vastly easier? -Randy |
Re: What tools to buy
While this set wont have all the tools needed Have you looked at the large Stanley tools set at wal-mart, I think its $75 or so, it includes the 1/4 ratchet and socket set, the 3/8's ratchet set, and the 1/2 ratchet set. I could be wrong on the price though.
Don't forget the antifreeze/coolant. If you buy the straight antifreeze, ie not the 50/50 mix get an equal number of gallons of distilled water. You do not want tap water in your engine, the minerals will corrode the inside of your engine. Last edited by 92 SVX; 01-24-2014 at 09:32 PM. |
Go to harbor freight and buy a half inch drive breaker bar. They're like ten bucks and way cheaper to break than your torque wrench. Hell, get all your stuff there. When you break it, take it in and they'll give you a new one for free.
PS, if you still have your stock lug nut wrench in the trunk, it's the perfect size to wedge in the access port on top of the engine to get the crank pulley off
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Thanks. |
right side back top of the engine, just in front of the bellhousing. There is a rubber plug in it that pulls out and gives access to the flexplate.
Thanks Tireiron.
Harbor Freight is fine for a 150' torque wrench, the things in silver are not needed for the job you want to do. A 1/4" rachet set also from Sears, and a 10mm Geardrive short racheting box end would save you time.
There is nothing quite so satisfying as using a good tool, nor quite so frustrating as using a bad one. For the stuff you'll use a lot -- 1/4" and 3/8" socket items for example -- be sure to get quality stuff that works and lasts.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss Last edited by wdb; 01-25-2014 at 11:12 AM. |
Since I am on a budget, I buy Craftsman tools for most of my work, Snap On is the best but about three times the price. If I buy some Harbur Freight stuff it's so that I can make a specialty wrench, you know, bend a 17mm and trim off two inches so that it fits an SVX application.
Thanks for the insight, guys. I'll probably get a decent set of sockets to start with since I have 2 Subarus to bring back to life just this summer, with who knows how many more to come.
I might have a Subaru addiction... Other than that, for the SVX timing job, are there any other torque specs that have to be very close? Or is everything just torque-til-tight? |
If you are not in a hurry keep an eye on tool sets from Sears. You can get some really nice sets at nicely reduced prices every once and a while. Valve cover gaskets may be a bit easier with 1. a set of ramps 2. some really shallow sockets like those pass threw design ones (like Gearwrench ones).
May be a bit too late for you but Sears has a sale on a nice set of sockets etc
http://www.techbargains.com/news_displayItem.cfm/391594 |
FYI Sears Craftsman tools are not always life time replacement. Lowes Kobalt are. They stopped when K Mart bought them out.
