Old 10-12-2007, 09:43 AM
etz bseder etz bseder is offline
I'm not sure about winter, but a good, all wet or dry tire is the potenza, it's worked well for me, but is too racey for the winter.
or at least for colorado winters with 3 feet of snow
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 10-12-2007, 09:44 AM
i will be using blizzak ws-50s this year and when they finally wear out, i will be going the nokian hakkapellajobs.
Old 10-12-2007, 10:09 AM
Turbone's Avatar
Turbone Turbone is offline
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
Originally Posted by louis View Post
what's a good set of all-weather tires that aint too bad in winter and aint expensive? that's what I need.
Check out Falkens, they are pretty cheap and not a bad tire either. Running them on 2 of rigs right now.
Verified Females
Old 10-12-2007, 10:12 AM
is that what you'll be putting on the murano wheels for which you outbid me?
Old 10-12-2007, 11:14 AM
processengr's Avatar
Hi all,
This month's issue of consumer report rates "Ultra High Performance all-season" tires, as well as "summer only" tires. The Continental Extreme Contact rated excellent in snow...quote "the Conti performed as well the dedicated snow tire used for comparison"
Top rated snow tires (not this issue, last years) were a Nitto and Blizzak Rev0.
Last winter in CT, I ran the above Nittos on my daughters car, and Hankook "Ice Bears" on my 92 Black over Silver. The Ice bear seems to be a regular high performance (V-rated) tire, with the tread compound for low temperatures. When it snows heavy, I take my 4WD toyota truck, but I fear "black ice" on my dailey commute with the SVX. Both SVX winter tires performed well, the Nitto was better in actual snow, but more snow tire like on dry.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 10-12-2007, 05:06 PM
Alright, after some though I think I'm probably going to just run my all-seasons through the winter, kill them, and then install snows on the stock SVX rims next year. I've been driving my Taurus with all seasons (more on the summer tire side though) for the past few winters, which is an absolute death trap, so the SVX should be a step up regardless.
Come summer I'll put on my new rims and summer tires:
Old 10-12-2007, 07:42 PM
immortal_suby's Avatar
Thread Killah
Originally Posted by AppStateSVX View Post
Falken Azeni 615
lol, down here those are my current winter tires!
Although mine are already down to the wear bars
Locker Link
2015 BRZ Limited 6MT
Old 10-12-2007, 07:45 PM
Cho Cho is offline
Send a message via MSN to Cho
Hey guys, I live here in the great state of igloos in Alaska and I have to tell you that for you to drive the SVX in the winter. All you will need is some All-Season tires if your car is stock or close to it. The year before my transmission died I had on Summer tires and I was able to go about my business in the snow just fine. If you cant manage it with All Season tires you might wanna slow down a bit. Because we all know if u crash ur svx, regardless if it had full coverage or liability, no insurace in hell is gonna repair it. They will just give you a few grand and off you go parting out ur svx. At least, thats my opinion.
Cho
1995 SVX L - Emerald Green
1992 Supra Turbo Red
Mods: Slotted Front and Rear Rotors, K&N Stock filter, Blue LED Interior Lights, and New Paint.
Old 10-12-2007, 08:32 PM
porschekiller porschekiller is offline
Banned
Exclamation snow and ice
blizzaks were the ones that made the breakthrough in studless ice traction and i've been loyal to them ever since they were tested on an ice rink. the q rated tires are the ones that stick to ice.
Old 10-13-2007, 10:18 AM
Turbone's Avatar
I would like to apologize for that. I didnt read all of the thread that the wheels were first posted in. And I dont know your Ebay name, if I had known you were bidding on them, I might not have bid on them. There were other auctions for Murano wheels and I might have bid on those. I'm sure there will be another chance to get some. And I rarely get out sniped in the last 10sec
And yes, I'm buying Falkens for the wheels. They are M&S tires and a set of 4is going to be about $550. So thats still a chunk of $ for wheels and tires, the most I've ever spent.
Verified Females
Old 10-13-2007, 11:26 AM
no need to apologize...i found these just a few minutes later. i just need to buy the svx center caps.
Old 10-13-2007, 11:27 AM
94SubieSVX's Avatar
94SubieSVX 94SubieSVX is offline
OOC for a while
Send a message via AIM to 94SubieSVX
bad link
bLAh
Old 10-13-2007, 12:57 PM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
After my time at the ice races, I'd have to throw my vote down for the nokian hakkapeliitta RSi over the Revo1's. They felt much more solid around corners, and most importantly IMHO when regaining grip after a slide or drift.
The Hakka line are also the most common tire run at the Sno-Drift rally every year.
Braking, the Revo1's and the Hakka's were about the same. As well as with acceleration.
Nokian makes a few different winter tires. The RSi's are best if you'll be on mostly slippery roads. (ie. roads that get plowed regularly, icy conditions.) If you'll be driving in mostly deeper snow that doesn't get plowed, the Hakkapeliitta 5 is the way to go (you can get it studless comply with local laws).
They've got other models aimed at mainly slushy conditions, etc... depending on the climate you're in. Winter tires (just like all-seasons) shouldn't be a one-size-fits-all scenario. Pick a tire that's made for your style of winter.
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 10-13-2007, 04:50 PM
Originally Posted by 94SubieSVX View Post
bad link
let's try again :
http://http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=005&sspagename=STRK%3AME WN%3AIT&viewitem=&item=150168826819&rd=1
Old 10-13-2007, 05:00 PM
AlcyoneDaze's Avatar
AlcyoneDaze AlcyoneDaze is offline
<-- custom hood ornament
Send a message via AIM to AlcyoneDaze Send a message via Yahoo to AlcyoneDaze
I've found my Kumho Ecsta ASX's to be more than competent for New Jersey winters, keeping in mind we haven't had a real winter for a few years now. Most driving is done in cold-weather but not too much snow on the roads, and during the occasional snowstorm, just slow down to a reasonable speed (which is somewhere around 80mph on the highway ) to prevent any hippie tree-hugging scenarios
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L
Donating Forum Member In Good Standing
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
