Old 06-26-2015, 12:59 PM
Received a nice little bit of money today from some back pay I was owed, enough to cover most of the cost of the roof, spoiler and deck lid repaint I had gotten quoted, immediately called the bodyshop and scheduled.
More money invested that I will never get back, but sometimes you do it out of love.
Old 07-05-2015, 07:16 PM
michael's Avatar
michael michael is offline
What Potholes ???
**deleted**
Wanted: Steering Wheel
Old 07-05-2015, 07:19 PM
michael's Avatar
What Potholes ???
Got my hood back from the body shop today!
Old 07-05-2015, 07:23 PM
That is really looking good Michael.
Old 07-05-2015, 08:05 PM
Absolutely Beautiful!
Old 07-05-2015, 08:27 PM
michael's Avatar
What Potholes ???
Thanks Guys, slow and steady. The whole thing needs to be repainted and I'm taking bit by bit as I can afford it. So far the trunk lid, roof, hood and passenger door are good to go. Bumpers, rear quarters, front fenders and mirrors still need to be done. It's not as nice as my pearly, but it's getting there.
Old 07-06-2015, 01:12 PM
theflystyle's Avatar
This might be a dumb question but did you take the whole car in to get the hood painted or did you just drop off the hood?? Also, can you give an idea as to what it cost to get the hood painted?
1994 SVX LSi
2008 Legacy 3.0R
Old 07-06-2015, 06:19 PM
michael's Avatar
What Potholes ???
Total came to $550 and I left the hood with them for a week. I had a spare to use while that one was getting done. I figured it would be easier for them if it was off the car.
Old 07-24-2015, 10:01 PM
simboglide's Avatar
simboglide simboglide is offline
Alternator and engine fan motor.
Old 08-02-2015, 10:51 PM
Coan's Avatar
Coan Coan is offline
Alleged User
Sold my '95 SVX today. Was tough to let it go, but it was a project that I was just not able to find time for.
Washed and waxed my '97 though... It still cleans up pretty well!
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 08-13-2015, 08:25 PM
Old Davy's Avatar
Old Davy Old Davy is offline
Update:
Update: whole lotta data-mining and came up with these. Magnaflow Canada has two alternatives worth experimenting with.
Part # 50004 - 3" dia, 10" long w center 2" in/out-lets.
Part # 54904 - 5" dia, 14" long w offset 2" in/out-lets.
Both listed compatible with SVX 1992-95. Not with 1996-97. Huh? Going for it anyway. If it flings out an OX sensor engine light, won't be any worse than what the cooked one has been doing for 4 years - just reset and cancel with OBDII reader. At least it will not knock out the Cruise Control as it does on the 2006 XT.
Eventually the rear main cat will be replaced with a readily available easy fit Magnaflow.
First we're gonna try the 3" dia one for a sure fit under shields and because hoity-toity Big Owen Sound Cobble Beach Concours d'Elegance Car Show in 3 days to which I would like to arrive in a quiet SVX
Crossed two more off the to-do list. Both front axles replaced with OEM units because of split boots. Was more economical to buy the entire units and tomorrow will return the old to the dealer for the core refund.
Have been driving...er...strong-arming the 97 around for 5 months with power steering leak; stopped holding any fluid at all 3 months ago. Photo-ed the source even after new pipes were put on. My main mechanic Chris was able to locate & tighten the offending junction with the axles out. No damage apparently to the pump running dry a few months. O-ring from Gwynethh did the trick.
What a difference. Duh :-).
First shout-out for new or pre-owned pre-cats:
...I have a cracked driver side pre-cat leaking sputtering exhaust note. It can only get worse and Chris doesn't want to mess with them now cause they'll likely fall to pieces. Heat shields are fine. After checking with his sources the only replacements Chris can locate are common cylindrical substitute precat resonators that would protrude down 2" into ground clearance, without shields.
I have searched the forums far and wide...and will continue until I get the definitive answer.
Dealership quote for OEM is $1400 smackeroons!!! for the left one only.
What are we replacing the three cats with now in 2015? Or do I beg for someone to sell me a pair off a salvage? Or does someone have an orphaned pair on a garage shelf gathering dust?
I sure do wanna keep him as originally engineered. Passed the Drive-Clean back in March no problem. Only need one for the left side but a pair would be best. Back 3rd cat is fine and un-clogged.
Please advise if you can, guys & gals. Thanks
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 08-14-2015, 12:43 AM
bishop bishop is offline
I've got a spare set on my parts car.
Old 08-22-2015, 07:16 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Changed out the fluids on the WRX. Just hit 3000 miles on the 207 swap.
Changed out brake fluid for Autocross. Some general undercarriage maintenance.
Also bought an Audi200 Quattro, and an E36 as my autocross car.
Old 09-08-2015, 11:09 PM
9005 low beam mod, new front ball joints, pulled the abs solenoid fuse since abs hasn't been working since the manual swap anyway.
Old 09-09-2015, 05:46 AM
The manual swap shouldn't have affected the ABS.....that's strange...
