Old 03-13-2013, 10:45 PM
kjoyes kjoyes is offline
Quarter panel replacement.
i have a rust issue on my svx the paint is starting to bubble around the wheel well, and the innner panel rust hole.
has any one attempted this, or should i just cut it out and patch it?
Old 03-14-2013, 08:54 AM
Re: Quarter panel replacement.
I'd recommend cutting and patching personally.
To replace the entire quarter panel, it includes removing the rear glass, rear, upper fixed glass, and drilling out the couple hundred spot welds, among other things... Though, it should be a better repair technically.
Old 03-14-2013, 04:39 PM
Your call, but getting a hold of quarter panels might be difficult, I don't know what Subaru's stock looks like for those. I lucked out and snagged a set that another member was getting rid of. I'll be replacing almost the whole panel on mine and patching the wheel well underneath. Reasons being that I'm anal, and that I'm pretty sure the lower sections of the panel that hides below the bumper and side skirts look like the Titanic on the ocean floor.
The patch would be cheaper, faster, less scary, and if the workmanship is good just as solid as changing the whole panel. Like Nate said, the whole quarter panel is a huge chunk of metal:
My plan is to follow the factory joints along the bottom and door jamb, but cut off the window frame and weld underneath the plastic garnish piece. Doing it this way keep almost all the welds (except the back one under the tail lights) hidden under something.
Old 03-15-2013, 06:07 PM
what does the inside of the panel, look like could you post some more pictures.
Old 03-17-2013, 02:19 PM
Sure, see the attachments.
Old 03-18-2013, 10:33 AM
dcarrb dcarrb is offline
Couldn't resist checking Subaruparts.com:
$316.79 + shipping, not in stock but "usually ships in 4-10 days."
I'd have guessed way, way more.
dcb
Old 03-18-2013, 10:39 AM
I know, they're actually very reasonable for the size of part you're getting. Buying all four quarter panels and fenders will only set you back ~$1000+ shipping.
