Re: pistons n cams
Re: pistons n cams
Am I the only one lol-ing at the fact that this was posted in "Interior Mods"?
Re: pistons n cams
But yea interior =! internals. Any thoughts on the actual question? Is it even remotely ok to swap in new pistons without having machine work done on the engine?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 12-01-2010 at 10:43 PM. |
Re: pistons n cams
I have been told that our cylinders wear into ovals. Mine were slightly out of round before my machine work. Suppose you would have issues with rings seating properly perhaps...
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Re: pistons n cams
Why not just avoid the hassle and just replace the MAF, injectors and maybe the cams? Unless you are going to do forced injection, what is the reason to change the pistons?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: pistons n cams
I agree, internal engine mods are about the worst bang for your buck there is. But yes, if you're replacing pistons, you really should do machine work. I've done so on my other cars with just a good cylinder hone, but they weren't out of round or damaged in any way. To "do it right" you really need to have the block machined to the right tolerances.
Re: pistons n cams
You can raise the compression ratio, put thermal coated bearings in, blueprint the engine, etc. All these things are essential for a true performance build. Subarus have tight oil clearances from the factory, which makes them incredibly prone to losing bearings or other parts of the bottom end. thermal coating components of the bottom end negates thermal expansion and allows for tighter tolerances to be run. It is a must if your engine is to be "perfect".
Re: pistons n cams
Re: pistons n cams
Re: pistons n cams
I'm not saying I'd just blow an engine up and throw it away, but I won't be doing performance rebuilds either, if I do get into rebuilding them...I'll be doing it as cheaply as is reasonable...or, more likely, selling the core to a rebuilder who will "do it right". I understand where you're coming from, and it sounds like you understand where I'm coming from, so I guess all is well. The only thing I'd argue against, is that people have treated EG33s as disposable, lol, and that there's a lack of parts availability (salvage anyway). The transmission problems with these cars have left salvage yards rich with SVXs, and parts gloriously cheap, in my experience. |
Re: pistons n cams
Also, "thermal coating components of the bottom end negates thermal expansion". I guess you are talking about coating the bearing surface. This won't stop the rod and shells from expanding due to heat from combustion. Harvey.
Re: pistons n cams
Plus, the bearing coatings are usually a dry-film lube, as opposed to ceramic for thermal purposes. Coating the pistons and head can certainly lower temps overall, though.
#28
Re: pistons n cams
It should go without saying that the only parts not affect by thermal expansion are the coated parts. Suppose I could have been more clear about that. And I say that they are prone to losing bearings because they do so at RPM's that many modern cars are comfortable at. 9k rpm is not much, especially when Porsche has engines that near 20k rpm redlines.
#29
Re: pistons n cams
Re: pistons n cams
I'm gonna talk with LAN and see what he thinks considering he's the one who designed the pistons in the first place, but if it's worth a try, I'll go for it next semester. Quote:
