wideband emplacement
for those who got a wideband... where to put the sensor?? i think the Y is way too far from the engine... but not really had the choice... what to do with this??
thanks! |
Re: wideband emplacement
nobody's running a wideband
Qesc que cest wideband?
Wide-band air/fuel ratio sensor- stock sensors are good for OEM engine management, but a wideband sensor is highly useful for engine tuning purposes. Optimally, they are placed very close to the exhaust ports of the hottest/leanest cylinder.
yea, but thats the problem with h6, after the Y isnt too far from cylinder?? i canot put it were the stock 02 is,coz i'll need two sensor or i dont know?
Just put it into one of the cat pipes just after the header/collector on the leaner side- I'm not sure if it's the driver or passenger side of the motor that gets fuel last without looking at my manuals, but there is no need to have it way back at the Y merge.
but,ill only get the signal from 3 of the 6 cylinder by doing this.... i'm missunderstanding a little also note that i'm running a megasquirt, stock 02 sensor are not used ,custom longtube headers and custom exhaust
hooo! and its not in a svx, its an eg33 in my 98 forester |
I installed my wideband on the passenger side custom made header.
Fuel enters on the drivers side, so the passenger side could be leaner.
and its "safe" to tune whitout the 3 other cylinder signal??i mean, if something on driver side fail, i wont really know when watching my wideband since it just "log" the passenger side head....?? maybe i just see problem where they weren't
If you only have one wideband A/F to work with, you are tuning for worst case, which would be the leanest cylinder, which is usually the last cylinder fed fuel in a stock Subaru setup. Are you going to be able to tell which of the six cylinders ran lean if you put the wideband back at the Y junction? Nope. Does it really matter as long as you know the side that could run the leanest is still in a safe area of tune? Nope, because the other side/cylinders are going to running a safe ratio because the leanest one is.
With or without a wideband if all three injectors on the drivers side went/go bad, go lean you will not know.
