Old 11-09-2012, 06:14 AM
'E''s Avatar
'E' 'E' is offline
sti alloy lateral links
looked through the suspension treads and couldn't see any treads for this so sorry if i'm repeating what some else has already done
I've always loved the look of the sti alloy lateral links, so I bought a set off eBay and fitted them up (they need a clean). The sti links weigh 2.964kg and the stock links weigh 4.178kg so that 1.214kg of weight gone for those of you on a diet
its a cheap sti mod and has good sti wank factor
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 11-09-2012, 06:27 AM
Re: sti alloy lateral links
Does that make you a wanker?
Nice job, looks good.
Old 11-09-2012, 06:36 AM
'E''s Avatar
'E' 'E' is offline
why yes it does
93 black SVX
95 bright red SVX
Old 11-09-2012, 07:28 AM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
What's a wank? Do wombats have them?
So, for the shade tree mechanics out there, is that mod for more bling appeal? What's the advantage?
I looks snappy.
BTW, love your wheel offset, looks slick the way SVX should be. Do you think it has any negative effect on your bearings?
Old 11-09-2012, 08:25 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You're just looking at the weight reduction, since they don't offer any more adjustment than the stock links do. Would be even sweeter if you milled off the one tab and had them anodized.
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-09-2012, 08:39 AM
'E''s Avatar
'E' 'E' is offline
I looks snappy.
Wombats are definitely wankers especially if you hit them in your car
It's sti bling mainly for me just so I can justify the sti badge on the back of my car but the benefits are weight saving and according to sti a more rigid rear end for better handling
No issues with bearings on the rear with that offset and yeah I love the rear guards being filled with wheel
93 black SVX
95 bright red SVX
Old 11-09-2012, 08:47 AM
'E''s Avatar
'E' 'E' is offline
Bill
Yeah I know there not adjustable but I not interested in adjusting them they are stiffer though and nice to look at when I'm lying under car swearing cause I just took some skin off my knuckles
I love the idea of anodising them, I was thinking of using the tabs for th sway bar
93 black SVX
95 bright red SVX
Old 11-09-2012, 01:40 PM
Cool. Good to know that the stock sti links are the correct length. I am using some adjustable ones currently, which I like.
Old 11-09-2012, 04:21 PM
'E''s Avatar
'E' 'E' is offline
lateral links are but not trailing arms
93 black SVX
95 bright red SVX
Old 11-09-2012, 04:27 PM
Yea, they are very far off right? So much that even the adjustable ones don't look like they can get to the right length, and probably would be angled wrong or something if they could.
Old 11-09-2012, 04:42 PM
'E''s Avatar
'E' 'E' is offline
yeah they are definitely shorter i think the angle is the same though.
with your adjustable links do you actually have them adjusted to a certain length or do you just have them cause they're cool
93 black SVX
95 bright red SVX
Old 11-09-2012, 10:35 PM
Well, initially, we didn't know that the stock STi links were the same length, so I only expected the adjustable ones to work. I have them adjusted just a little bit because the car's lowered a little bit. I also am planning for later, taking the car to the track and stuff, I want to be able to adjust them.
Old 11-10-2012, 03:02 AM
'E''s Avatar
'E' 'E' is offline
Cool
93 black SVX
95 bright red SVX
Old 11-10-2012, 07:20 AM
Tireiron Tireiron is offline
I have the whiteline adjustables also. They are nice because you can dial in whatever camber you want to run. On subarus I like to start with -1.5 all around and work from there based on how it feels and acts.
Changing the trailing arms out won't make much difference. The OEM arms are quite a decent design and once you replace the trailing arm bushings it tightens things up significantly.
Adding diff bushings, outrigger bushings, and subframe bushings really locks everything down in the rear. I've gotten rid of all the rubber bushings in the rear. The only rubber bushings left in the car are the front control arm bushings.
Old 11-10-2012, 03:46 PM
'E''s Avatar
'E' 'E' is offline
I've got camber bolts on my rear struts to pull the top of the wheel in because of the 22 rear offset I'm running so don't really need the links to be adjustable. I've found the rear camber works really well with cornering
I plan on taking all the rubber out at some point myself, did you notice much of a difference in noise and vibration?
93 black SVX
95 bright red SVX
