Spark Plugs & Serpentine Belt.
Hey all. Well I have my ATF cooler and SmallCar shift kit. But I can not work up the nerve to install them myself. I m very certain I can do the shift kit but the ATF is looking to be a daunting task. I would like to at least get it installed before too much longer.
Anyway my real question. The Spark Plugs look really hard to get to. Any special tools besides a ratched and a plug socket needed? Any specific kind of plugs reccomended? Also my serpentine belt is looking really badly worn. It is missing bands of teeth. Anybody know how hard it is to fine a new belt? And about how much they run for? Is it as simple and loosening the tensioner, pulling off the old one and puttig on a new one or is there more than that? Thanks, - Jason |
Spark Plugs: Any old ratchet is fine (well, one that fits; I think it's 5/8in.), but I have this one that has rubber and holds the plug as you take it out of the engine compartment; quite handy. As for specific plugs; any plugs gapped to the SVX requirement are ok. I myself just got a set of Bosch 4+'s and really like them (you don't ever have to gap them). I would make sure they are at least platinum tipped though; they'll run you maybe $2-$4 a plug. I also have read that you probably want to take off the box that has the air filter in it to give you more clearance to get at the plugs.
Belts: Serpentine Belts are easy to get. The ones for my legacy (I bet the SVX takes ones very similar) were around $9 each. If your belt is missing a band of teeth, I'd get it off there quick. If you've got a few extra bucks, you can get gator belts which tend to last longer (someone can correct me on this). And yes, it is just as easy as you described to get them off. I loosened the idler pulley to the the AC one on and I tilted the alternator down to get that one on. Subaru was quite ingenious when they made the engine .
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi Last edited by Manarius; 07-21-2005 at 07:37 AM. |
Which belt are you refering to as a serpintine belt? If you are talking about the AC and Alternator belts, they are easy to find and can be found at subaruparts.com if none of the parts houses don't have them locally.
Here is the link to the instructions to replace the spark plugs. It is in the How-To Documents for future reference. Some of the other tasks that you mentioned are there too. Good luck.
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=”silver”]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 Last edited by ensteele; 07-21-2005 at 09:42 AM. |
First of all, because you don't yet have an SVX, you don't realize how tough the plugs are to get out. They are cake on a 2.2, but the 3.3 is a different beast. The plugs on the 2.2 sit near the top of the head and are angled upward and are pretty clear of obstructions. The plugs on the 3.3 are located in the center of the head making it awkward to get in there, and each one sits behind a coil that's bolted on. Once you know the shortcuts it's not so bad......but not anywhere near as easy as a 2.2 plug job. Secondly your "any plugs gapped to the SVX requirement are ok" is misleading. Gap is only one aspect of spark plug requirement. You need to make sure the heat range is the same, and if you are going to match the originals, you want platinum plugs. Dave |
And any auto parts store isn't going to sell you ones that don't match heat wise. If you go into autozone and ask for plugs for a 92 SVX, they're going to match when it comes to heat.
The SVX doesnt have a serpentine belt does it?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
They are alot easier to change than the sparkplugs. A transmission cooler is not too hard to install, and a good move.
No. A serpentine belt is one belt that drives multiple engine mounted accessories. All Subaru's (except those with the 3.0L engine) have two seperate belts that drive the accessories. Dave |
Not always. I worked in the aftermarket for years. Not all brands have identical heat ranges. If you want Bosch and Bosch doesn't make a plug that matches the SVX heat range, they'll sell you the next closest heat range. I did it for years. Dave |
So the coil sits ontop of the each plug!? That is different. I thought those flat "covers" looked strange. I will look in the documents on how to do it.
Any specific brands that folks have had good luck with. I am not looking for like super amazing performance, just long lasting and reliable. Ensteele: It is the belt on the front of the engine that winds around all kinds of pullies. It has bands in it and some of them are missing. I wonder if that could be the cause of my engine reving up to around 1500 when I first turn it on then some times dropping down to 200 RPMs. May also be the reason that my check engine light is coming on intermittantly. That is, if the belt is slipping. |
