Old 06-27-2007, 08:34 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I know that the Koni's are starting to leak... but they are covered by warranty. Wouldn't it be a better buy to stick with Koni's that have a lifetime warranty to use in that kind of coilover setup? That way people wouldn't have to worry about having to buy new cartridges later down the line.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 06-27-2007, 02:32 PM
This is good! My 15 year old stock suspension is unhappy and very sloppy. I'm definitely in.
1. Stevebsy
2. Mission
3. SVXMAN2001
4. SVXRide
5.SVXBart
6.Crazy_Pilot
7.
8.
9.
10.
etc.
1/5th of the way there!
Old 06-27-2007, 05:16 PM
drivemusicnow's Avatar
Poor College Racer
Shocks like these (or at least what I'm ASSuming these are) are easily rebuildable, by either the manufacturer, or sometimes the end user. Typically re building can be done for around 50$ a corner, and if the are a reputable shock, will offer much better performance, and adjustability. plus the pillowball mounts will offer easy camber adjustments, as well as possibly castor.
Also, Koni's are said to have a similar lifespan, and should be rebuilt every 2-3 years or so as well.
Questions I would have would be:
Inverted Monotube design?
Whose shock internals do they use?
would shock dynoing be an option for those buying them/could the present some shock dyno data for their shock on a different application?
Is it Megan Racing?
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 06-27-2007, 05:36 PM
mbtoloczko's Avatar
sans SVX
Answers to questions:
*Cost to replace worn struts: $75/strut (includes only the strut body which is the main wear item)
*Replacing worn out struts: The manufacturer takes your credit card info and sends out a replacement strut body. If you return your worn out strut body within two weeks of receipt of the new body, the $75 cost applies. After two weeks, they charge as if it was a new strut body.
*They do not weep oil until they are worn out.
*Shock design: monotube
*Shock internals: their own
*Shock dyno data: none provided, but a prototype set would be built, evaluated on someone's car, and fine tuned prior to going into full production.
Mychailo
Visit my locker
Old 06-27-2007, 06:35 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Got me.
1. Stevebsy
2. Mission
3. SVXMAN2001
4. SVXRide
5.SVXBart
6.Crazy_Pilot
7. Sov13t
8.
9.
10.
etc.
Subaru SVX 94' Laguna Blue - 8.5 C/R Built Motor, 6spd
Old 06-29-2007, 10:07 AM
wawazat??'s Avatar
Yeah, I'm still around
I'm on the fence my friend. Depends what Koni does next with the set I've set for evaluation that have been leaking. I think I know the maker and if so I've heard good things about their products.
Todd
Down to none
Old 06-30-2007, 07:42 AM
mbtoloczko's Avatar
sans SVX
I heard you were looking at some DAs. It would be good if one of us could work out a solution.
Mychailo
Visit my locker
Old 06-30-2007, 11:23 AM
wawazat??'s Avatar
I know how to contain the inserts in our housing and have the parts on hand, I just need to pick the insert and drop major coin for them. I need to confirm if Koni intends to repair my inserts under warranty or not before I give them any more business.
Todd
Down to none
Old 06-30-2007, 03:22 PM
SVXelerator SVXelerator is offline
Frequent User
Tein? Eibach? H&R?
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 07-01-2007, 07:21 PM
mbtoloczko's Avatar
sans SVX
ok folks, I don't see any point in holding back any longer on the manufacturer. Its Megan Racing. They have been making a name for themselves for the past four years making inexpensive but good quality aftermarket parts for import sports cars. They are able to keep their pricing down by having all the fab work done in Taiwan or China. They currently make coilovers for a pretty wide range of cars. The street series coilovers would be the most appropriate for the widest range of SVXers because the damping is tuned for a spring rate more appropriate for the street, but they can still handle track duty and a somewhat higher spring rate for the competitors out there. A pic of what they would look like is shown below. If you want to see what range of cars they currently cover, here is the street series webpage:
http://www.meganracing.com/products/...e.asp?catid=93
Mychailo
Visit my locker
Old 07-01-2007, 10:22 PM
Noir's Avatar
Noir Noir is offline
Very nice Mychalio. I maybe interested in a set but will let you know as the numbers grow. I should be removing my set of Koni/GC's for inspection and will need another set to use if I have to send them back to Koni.
I've always wanted to try your springs but like Todd, I hacked off the spring perches so that was impossible. This should be a nice alternative. I will be monitoring the status of the group buy and they do look like very nice bolt-in's.
Old 07-02-2007, 03:13 PM
Jnthn_Sctt Jnthn_Sctt is offline
Question Sway Bars??
Are sway bars available as well? Front / Rear??
I'm very interested
Good people sleep peacefully in their beds at night, only because rough men stand ready to do violence on their behalf.
Old 07-03-2007, 02:51 PM
Poor College Racer
I win!
I'm going through a lot of suspension research right now, so it just kind of sounded a lot like Megan Racing.
I've heard good things from everyone who has them, but i'm still hesitant.
See if you could demand shock dyno data, because even a baseline would be good to know. IE: what kind of adjustment range do they have, what kind of force curve does their valving produce, and are they linear, digressive etc.
I'm still undecided between something like the MR coilovers and a Koni/truechoice/hypercoil coilover setup for my track car.
Greg
Old 07-03-2007, 07:03 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
The must have reinforced sway bar end link mounting hardware
-Bill (having had to reweld the hardware on both front struts and then add a tab to the driver's side hardware after the top tore out of it )
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-05-2007, 07:41 AM
mbtoloczko's Avatar
sans SVX
Remember, this is all just idle discussion until we reach 30 buyers. Long ways to go. :-(
Mychailo
Visit my locker
