Tire PSI for 225/45-17's
So on my summer tires which are 225/45-17's. Should I run the same pressure as the stock 225/50-16's or should it be different?
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
Re: Tire PSI for 225/45-17's
That's going to vary by tire model and by what you want the tires to do. We need a lot more information.
What Rob said. I run my 245/40/17's at 40 front, 35 rear because I find the General Exclaim UHP's a little on the mushy side.
I have 225/50/16 Pirelli P Zero Neros that I typically keep at 40psi front and 38psi rear for a balance between a firm and smooth ride.
Come winter, I use 205/55/16 Bridgestone Blizzaks somewhere in the mid 30s. I also have 245/40/17 Bridgestone RE01Rs for autocross days, running 40-44psi depending on track conditions, and there's never any appropriate match front to back. At Cherry Valley (our local kart track), I bump the front right tire 2psi because of the track's shape! My science? Best guess and feel for initial setting, and manufacturer's recommendation for proportion.
I have the Kumho Ecsta ASX. The door sticker for the stock size is F33 R29 and that's the pressure I use for my winter tires. Since these are a different size I wasn't sure. I just want to make sure I don't run them too low because of heat build up or too high and cause them to wear out too fast.
You can just put in whatever the max. is on the tire (it'll say in small print right on it) and then just subtract a few psi (4-ish) from the rear tires.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
