Old 04-27-2010, 09:45 PM
zavikan zavikan is offline
Send a message via AIM to zavikan
Will this fit? Universal Bolt Pattern: 5 x 100 + 5 x 115
Found some wheels. this is the bolt pattern listed. does this fit the SVX?
James
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 04-27-2010, 10:57 PM
Re: Will this fit? Universal Bolt Pattern: 5 x 100 + 5 x 115
Are you sure it's 115? Or just 114.3 rounded off? Either way, sure, they'll fit.
Old 04-28-2010, 02:15 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
They're just drilled for both. If they are, in fact, 115, then they will not fit.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-28-2010, 02:16 PM
92 SVX 92 SVX is offline
-Bill
I believe they should, GM cars that use 5 x 115 pattern can use 5 x 114.3 with no problem.
Old 04-28-2010, 03:00 PM
With some grinding, I fitted 5x112 rims of the Mercs on mine.
Old 04-28-2010, 04:57 PM
BoxerFanatic's Avatar
5x115 is probably just a rounding issue. Most imperial measurements say 5x4.5 inches. That literally translates to 114.3mm... to one decimal of precision, but some may just round to 115mm. It is a nice round multiple of 5.
Seven tenths of a millimeter is hardly a major difference. Some wheel studs compared to others may have more than .7mm difference in bolt circle diameter.
Chances are, if it is dual-drilled, it is drilled for 5x100 (subaru, VW, Scion, and others use that), and 5x4.5inches (almost everyone else from japan and the US use that.
Metric european cars tends to use 5x100, a bit of 5x110, 5x112, and 5x120mm. And I think most of that is to be enough different as to not cross wheels between european brand cars. BMW wheels on Mercedes, Mercedes wheels on Audis, Audi Wheels on Ferraris, and Ferrari wheels on BMWs... it would be chaos.
American and Japanese manufacturers seem to like the lower costs of modularity, rather than worrying about wheel design cross-over. It is also cheaper for suppliers to offer a more standardized set of parts. Not only wheels, but brake discs or drums, and hub assemblies, all have to be set to that pattern.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 04-28-2010, 05:44 PM
5x114.3 is the lug pattern.
Whats the width? Whats the offset?
Are they cheap?
I am on the look out for some cheap rims...
Got a link?
Old 04-29-2010, 12:01 AM
Are they cheap?
Got a link?
One of the best rims on an SVX are the RX-8 ones. They are 18's and go around 300~400$ for a set. Check out Green1995SVX for photos.
As for the aftermarket wheels, and related to my last purchasing experience, i suggest you guys ask for the hub diameter also. You might need rings for that.
Old 04-29-2010, 04:14 PM
I dunno...Mike is certainly a trend setter...but the wheels I'm looking at are a throwback to his non pearly days...
Got a local guy selling a set of these.
File Type: jpg 3n63k93o65T45P65R3a4e85f4cfdcceca1f75.jpg (5.5 KB, 318 views)
Old 04-29-2010, 04:51 PM
Enkei Shoguns, am I right? Probably 17x7 or 17x8... Otherwise a knock-off of them.
I've seen pictures of a green SVX wearing those. Evidently, Mike's pre-pearlie car, if this cardomain page is for the same "mike". http://www.cardomain.com/ride/286975
Pretty sure they'll fit.
Most aftermarket wheels are made to fit a wide variety of cars, and a FWD fitment like that should have plenty of positive offset for SVX fitment. They even appear to be directional, if those photos above are accurate, and one isn't mirrored. Both sides of the car have the wheels "clawing forward".
The hub bore diameter is likely pretty wide to fit a variety of cars that might have a wide hub ring diameter, so some hub ring spacers are likely a good idea, and SVX OE lug nuts won't work with those wheels. 12x1.25mm (IIRC) thread pitch for Subaru or Nissan fitment (wheel stud threading), with the same seat style (likely conical) as those wheels will be required. Probably narrow over-all diameter "tuner" lugs. McGard Spline-drives work well for that.
They'd be sexier if they weren't double-drilled, or had fitted center cap covers over the hub area, but those are good lookin' wheels.
Old 04-29-2010, 06:26 PM
ZMan's Avatar
ZMan ZMan is offline
Probably would have been easier to just drive over there and put one on.
Old 04-29-2010, 08:04 PM
to bad my svx is 5 hrs away yawning at the snow in NH....
