#91
#92
An impreza fpr probably costs a little bit of power and worsens fuel efficiency on a car with our software. It might improve things a bit on a car with a stock ecu since the cars run way too lean at low rpms from the factory but we've already taken care of that in our software. |
#93
Thus my question about the 2V3 chip for those of us runing the Impreza FPR and upgrading to the 2V3 w/z32 in a NA mode Definitely don't want to be doing anything that's going to reduce the amount of Hp/Torque being created (and I really don't want to have to go back in and swap out the Impreza FPR, since my stock FPR was on its last legs when I replaced it with the Impreza FPR...) -Bill p.s. Long term, I think the Impreza FPR is the right way to go, as it pumps up the output of the stock injectors so they'll be capable of supporting the higher Hp/Torque we're all working towards
#94
But if I tuned for the impreza fpr then everyone who doesn't have one would need to get one when they wouldn't otherwise need it. I feel your pain but I don't think the majority of people would want to buy a new fpr that they don't need. |
#95
I fully understand your thinking, from a business standpoint (must be that minor in Economics that came with the Mechanical Engineering degree )...I just keep coming back to the following: Stock FPR with Stock Injectors = 36psi with 240 cc/min = 230 HP @ crank Impreza FPR with Stock Injectors = 43 psi with 270 cc/min = 260 HP@crank (Based on BSFC=.45 and Max Duty Cycle = 75%) Granted this is a "theoretical" calculation...it just gets me to thinking that, just as the stock MAF has become a "bottleneck" for further HP gains (2v3 w/z32 MAF to the rescue!!), the stock injectors with the stock FPR are the next "bottleneck" we're faced with and the Impreza FPR does help us in this regard. -Bill
#96
#97
If you are running lean because you have reached the limit of the fuel injectors and then add the fpr to increase your fuel flow then you won't be running too rich and loosing power will you? At that point you are correcting your afr to get back to the sweet spot; however, using the fpr to raise your fuel pressure if you have not increased your airflow is a bad idea and asking that I take out extra fuel to undo a few people's bad idea to the detriment of everyone else is kind of well..you know.
If you start running lean by all means raise your fuel pressure. You are worrying over nothing anyway. By now you should realize I always tune in a way to allow the largest margins of variablity between cars. Not like I went and pulled the walboro out of the demo car I did the fuel tuning on. In the demo car it runs 12.9 to 12.4 at wot accross all rpms on the street. |
#98
It seems like the Stage 2 chip is designed to handle increased air flow, which, if it were available might tax the stock FPR. So, for those of us who are not yet ready to put $5-6K into a forced draft system, what might be the options for increasing airflow, so that we could get to this lovely dilemma of being too lean?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#99
Great! Given the dyno results I got when I put the 1v4 in my car - AFR curve indicating a little richer than I'd like in the upper rpm range (backed up by very black head pipes) - I've been axiously waiting for your next "stage" Looks like the 2v4 w/z32 might just get those of us looking for even more Hp/Torque into the "sweet spot" Can't wait to get everything together and get back to the dyno (yes, I've addressed the issues we discussed with my last runs ) -Bill p.s. the 12.9 to 12.4 you refered to is with the 2v4 w/z32 MAF?
#100
#101
I have it in hand. The z32 maf allows the ecu to drive the injectors harder if need be and the changes i made to the vq table in order to effect the afr has the injectors not being driven as hard as they were before at high levels of output while at the same time increasing power output--or so I believe we will find out tomorrow.
This is running a walboro fuel pump the effect of which is somewhere between stock fuel pressure and if you had an impreza fpr, a good happy medium. The effect of this is to make the software work for everyone, to improve accuracy of the engine management at high ouput, reducing fluctuations in afr and combustion temps between cyllinders and revolutions while increasing acuracy of timing control, allowing us to increase ignition advance for further power gains, while lowering injector duty cycle at high output thus increasing possible output and rpms. |
#102
Just got my Stage 2 V. 4 kit. For some reason, the Ecutune website wouldn't come up. Instructions not absolutely precise on one point. The switch is only for changing to lower octane rating gas, is that not correct. If we want to continue to pay through the nose for high test, we don't need to install the switch.
#103
Why would running a walbro pump have an effect between the stock fpr and the impreza fpr? Isn't the walbro pump just increasing the maximum flow rate? Ultimately the fpr is still controlling the fuel pressure that the injectors are seeing. Maybe I'm just missing something here Thanks again for all your hard work in support of the EG33/SVX!! -Bill p.s. can you provide a little more detail as to what you mean by "The z32 maf allows the ecu to drive the injectors harder if need be..." Do you mean a higher duty cycle?
#104
When I installed my Walbro 255, it did nothing to my fuel pressure at all...
But I have had a fuel pressure dropoff when I shut off the engine, for a long time, most easily explaned by a leaking fuel injetor.
#105
-Bill
