Tranny flush and fill
How much is a tranny flush and fill on average for these? I'm getting $150 bucks from the dealership...seems pretty high. What's involved if I do it myself or have a friend help? Thanks!!
P.S. Where's the hood latch on this thing? I pulled the lever under the dash but can't get the hood up! lol |
about 89 at local shops here.
Greg |
What you want to do is drain and refill the trans, while it safely supported by jack stands. 4 quarts will drain out quickly, and 6 if you let it drain for two hours. If you do this four times, driving it for a day after each drain and fill, you will have MOSTLY changed out all of the fluid. And having done it yourself, not forced the seals askew with the high pressure MOST trans fluid exchangers use. You have only spent $32-$48, and you have NOT DAMAGED your trans in the process. P.S. Have a friend lift up on the hood as you pull the hood release.
That is some cheap tranny fluid. I would go for the good mobil synthetic stuff. Cools and flows better.
Greg |
BUT you know "the garage/dealership" is using the cheapest stuff that still flows and looks red! The idea is, my hope is to get people to change their OWN trans fluid, so that it gets changed! When I do a trans swap, I use the cheap stuff, just to flush the system of debris. However, I recomend/ask that they change to the good stuff at the first chance. 12 quarts @ $5.00 a quart is $60.00, plus tax and not everybody can afford that. And the trans is not set up like an engine, when you drain it(an engine) it is almost fully drained in 5 minutes. I USED to change the tranny oil every time I changed engine oil, about every 6000 miles,(Mobile1 full synthetic ), but with a good full synthetic ATF, you can run it longer. I want all of us to take care of our SVXi. They are not making any more.
There is a small lever just right of center under the hood that needs to be moved to the left to open it.
