Old 11-23-2011, 10:05 AM
92NJSVX 92NJSVX is offline
Replacing headliner
Im getting ready to replace my headliner and have an issue. I was looking in the on line manuels and even when I look at the OEM sites my sunroof switch is different then the ones they show. Here is a pic:
Has anyone seen this before? I did not want to start ordering items and not be compatable.
Thanks,
Adam
Old 11-23-2011, 10:35 AM
Re: Replacing headliner
Definitely an aftermarket unit, not OEM
Even the trim molding looks different; factory ones are matched to the headliner and more suede-like.
Is your car an LS model?
Factory switch panel had the sunroof open/close controls in the center, flanked by a map light on each side and a row of four buttons.
An very odd photo. Any more pictures?
Old 11-23-2011, 11:07 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
An interesting question: Is the sunroof panel itself OEM or aftermarket?
Old 11-23-2011, 11:20 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Question Re: Replacing headliner
It may be an OEM - but fitted to a non-sunroof model SVX?
With an aftermarket open/close switch
Also the rear mirror mount looks different to mine here in NZ ?
Old 11-23-2011, 05:10 PM
Its an LS. Also the headliner is not solid. There are some solid parts on it but for the most part its fabric stretched acoss. There is also a leather line down the center and the light is tword the back.
Old 11-23-2011, 07:15 PM
The sunroof is aftermarket, the headline that is there sounds like they modified the stock non-sunroof headliner.
Old 11-23-2011, 07:41 PM
That sucks. Sounds like I have to go to a custom shop and get a new headliner made. Going to be expensive.
Thanks for the info.
Cheers,
Adam
Old 11-23-2011, 08:43 PM
Is the sunroof glass by any chance?
Old 11-23-2011, 08:49 PM
Probably. It's not going to be a piece that would fit in place of the OEM sunroof though. It's just going to be a generic aftermarket moonroof assembly
Old 11-23-2011, 08:53 PM
That would still be pretty cool. Unique.
Old 11-23-2011, 09:03 PM
There have been quite a few done that have popped up on the forums. Typically aftermarket sunroofs start leaking after a few years. They also sacrifice the structural support of the roof. There is a huge difference with how the OEM sunroof and non sunroof SVX roofs are strengthened.
Old 11-24-2011, 07:08 PM
It is a glass roof. No leaking ever. At least in the 12 years I have owned it. It also has a plastic incert that clips in to the glass.
Old 11-24-2011, 07:15 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
i have that EXACT same switch. i wonder if this was something subaru dealerships offered back then? i'm having the same problem with my headliner as well. my sunroof is glass too. i get a few drops of water that leak, but very rarely and only during extremely heavy rains, doesn't bother me. i was going to fix mine by ripping off one whole side and spray-adhesive it back together.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 11-24-2011, 07:35 PM
Yeah, Not sure but if you have the same switch then maybe it was either the first sunroofs put in or a Subaru specific sunroof.
Old 11-25-2011, 08:54 AM
B 4 You's Avatar
#lolsvx
i don't know, because the stock svx sunroofs are supposed to be painted on top and carpeted on the bottom. you and i are fortunate enough to see through them
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
