Old 11-02-2011, 01:11 PM
rlwpromo rlwpromo is offline
Hood Release Cable Broke
Hello,
My hood release cable broke and I would like to know if anyone has information on how to get under that hood when this happens and then how to fix it.
Thanks,
Robert
Old 11-02-2011, 01:48 PM
Re: Hood Release Cable Broke
Can you tell where it broke? Maybe you could still pull the cable from inside the car if it broke at or near the handle.
Old 11-02-2011, 01:54 PM
I'm not sure exactly where it may have broken or if something else is wrong. I pulled it and it didn't have that normal feel where you can tell the catch is releasing. It seems to be fine near the handle and I tried tracing it and using pliers thinking maybe there was something wrong with the handle in the car.
Old 11-02-2011, 02:08 PM
did you try having someone else pull on the hood while you mess with the handle? or push it down hard to see if it isn't in the catch all the way? not frequently but sometimes my hood won't open without 2 people (or a doorstop jammed under it) and the handle doesn't feel like it is doing anything.
Old 11-05-2011, 02:58 PM
juice's Avatar
juice juice is offline
Juice
once this happened to me and someone had flipped the switch in the trunk to stop the handle from working check the most simple stuff first.
Old 11-05-2011, 03:06 PM
juice's Avatar
Juice
sorry i thought it was the trunk lever
